Old 06-11-2002, 02:05 PM   #1
don t. - 72gmc
Compression test results - good or bad???
A guy at work loaned me his tester. I did a dry, then wet test.
I have no idea if this is good/bad. Im not having any (major) problems. Figured I'd ask the experts.
Did each cylinder 3 times, cranked over 5 times each time. Did all dry, then started back at #1 w/the wet test. Truck has been sitting for 3 days prior to test.
Watchya think????
1 - dry=130/130/130..wet=140/130/130
2 - dry=135/130/130..wet=130/130/130
3 - dry=135/135/135..wet=135/135/135
4 - dry=135/140/140..wet=140/135/135
5 - dry=135/135/135..wet=140/135/135
6 - dry=120/115/115..wet=115/115/115
7 - dry=135/130/130..wet=140/135/135
8 - dry=130/130/130..wet=135/135/135
Thanks...don t. ....
don t. - 72gmc is offline   Reply With Quote
Old 06-11-2002, 02:11 PM   #2
Mike C
Mike C's Avatar
It has worn very consistently and the rings appear to be in good shape. Looks like you may have a leaky valve on that one cylinder.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-11-2002, 02:20 PM   #3
tom hand
CCRider
tom hand's Avatar
I would say there is no problem. Sounds a little low but that could just be the guage. The biggest thing you look for in a compression test is difference. If the motor was worn out the numbers would be all over the place.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-11-2002, 04:30 PM   #4
COBALT
COBALT's Avatar
Since I'm a complete knob sometimes, and I've never done a compression test (wet, dry, windy, snowy, or sunny - lol) how do you do one? What kind of guage do you need to get, and how does it hook up?
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-11-2002, 04:39 PM   #5
Gordo
It's considered a healthy engine when they are within 10% of each other. #6 looks like a valve may be leaking (as stated earlier) but otherwise your in good shape. I would moniter that cylinder and test it again in a few K's.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 06-11-2002, 06:34 PM   #6
don t. - 72gmc
New69...the guage I used was from SunTest. Those were the only words on it. The guy said he's had it for years, used it twice. It screwed into the spark plug hole. Take all plugs out, I also disconnected the coil bat wire to be safe. Had my kid hit the key for 5 revolutions, did this 3 times on each cylinder. Did all 8. Started back at #1 w/a teaspoon of new motor oil. Did it all over again. I really wanted to use it for my 9n tractor (which aint as good).
2 more questions for the board...
1 - would Marvel Mystery oil work/clean up the leaky valve?
2 - what should the specs be?
Thanks again.....don t. .....
Old 06-11-2002, 07:36 PM   #7
john
member #16
john's Avatar
comp test
You should have the throttle open when taking test,which might help your readings. If you have stock engine and comp. ratio those readings dont sound bad for a angine with some miles on it.
john is offline   Reply With Quote
