04-24-2005, 01:58 AM | #1 |
Do I have air or not?
Just a quick question which is probably a crazy one but here it goes... How can I tell if my truck has air? On my switches under the radio there is a switch called Air/fan...in the fuse box theres a fuse marked air. Under the dash next to the firewall sitting on the floor theres a box thats rather large which I am not sure what thats for. But in the glove box on the list of items that came with the truck, "Air" is not listed. Its a 69 custom camper C-20. Any info would be great.
Truck69 |
04-24-2005, 02:19 AM | #2 |
A quick way to identify if you have air in the cab is... there will be a rectangular air vent directly above the radio location on the flat metal dash itself and there will be 2 round air vents, one on the far left of the dash next to the gauge cluster bezel & one on the far right of the dash next to the glovebox door on the dash also, hope this helps, Doug
04-24-2005, 02:52 AM | #3 |
Thanks. Nope...Nothing like that in my truck. Thanks. for the info.
Truck69 |
04-24-2005, 02:56 AM | #4 |
Got Light Emitting Diode?
couldnt it be an add on, not factory? do you have a pump under the hood? passenger side top of engine
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
04-24-2005, 06:16 AM | #5 |
If you open your hood, there should be several items (if you have a/c). The first thing you might look for is an a/c compressor. Without one of them babies, you gots no air.
T |
