Old 04-24-2005, 02:50 AM   #1
texxxas
frame swap ?
hey... does anyone know of a maybe mid 80's frame that would work fairly simple under a '58 SWB... any possibilities by removing CV joints from a front wheel drive donor frame...could it be used with a drive shaft type application?
David
texxxas is offline   Reply With Quote
Old 04-27-2005, 10:39 AM   #2
1-ton of fun
polishing a turd
1-ton of fun's Avatar
i have read that s-10 frames can work
1-ton of fun is offline   Reply With Quote
Old 04-27-2005, 06:16 PM   #3
Norselander
Clunker Farm, Proprietor
Norselander's Avatar
http://67-72chevytrucks.com/vboard/s....php3?t=150626
Drew
Chief Junk Jockey
Norselander is offline   Reply With Quote
Old 04-27-2005, 08:11 PM   #4
bigblockguy
frame swap
Are you looking to use a 2wd or 4wd frame? I have a '62 Chevy 2wd frame and a '63 GMC front end that uses torsion bars (makes it very easy to raise and lower the front end and keep front end geometry correct). Where in Texas are you located?
bigblockguy is offline   Reply With Quote
Old 04-28-2005, 03:14 AM   #5
texxxas
thanks guys...2wd is what i am wanting...i live in northeast texas...norselander did you have any problems later because of moving spring hangers?
Old 04-28-2005, 06:45 AM   #6
bigblockguy
Email me direct at 81vette4speed@cox.net - I may have what you're looking for.
Old 04-28-2005, 03:47 PM   #7
Norselander
Actually, the former owner set it up. It hasn't been completed, but it looks pretty good. Should I use this setup I will make certain that the driveline angle is correct (optimized). This may necessitate a slight rotation of the rear axle housing.
Drew
Chief Junk Jockey
Old 04-30-2005, 12:46 AM   #8
qksilver
I am doing a swap on my 57, using a 66 frame , all the measurements are so close as not to be a problem. I am using the cab and core support mounts off the 57 frame. Otherwise spacers etc, it will look clean and factory when done. 2 things to work out are the steering coloum and mounting the brake booster on the firewall. I am using a 72 power booster and the hanging pedals.
As far as the cab mounts go, I drilled the rivets out, clamped them in place, same distance above frame as on the 57 and then redrilled the frame to match the 57 cab mounts. I used grade 8 bolts. Much cheaper than updating the 57 frame to get a modern style front and rear suspension
qksilver is offline   Reply With Quote
Old 05-04-2005, 12:49 PM   #9
OldJimmy57
QKSILVER, I just did the very same thing. Except I am using a 68 Frame. So it already has the demples on the frame for the gear box from a later style to bolt up to. I am also setting a 1957 body down on this in this configuration. I guess I may need to start my own post about all this. E-mail me sometime and I will try to get some pics posted.
http://67-72chevytrucks.com/vboard/showthread.php3?t=145432
OldJimmy57 is offline   Reply With Quote
Old 02-22-2006, 01:20 AM   #10
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
Re: frame swap ?
just a bump to check in on qksilver and oldjimmy57s frame swap projects? bougth a 62 hauler and looking to set a 57 cab and front end on it any info, updates, pics would be great!
milehightoyz is offline   Reply With Quote
Old 02-22-2006, 02:55 PM   #11
cadman89
cadman89's Avatar
Re: frame swap ?
I posted about a guy in St Augustine with a 55 on a72 with pictures...
http://67-72chevytrucks.com/vboard/s...d.php?t=189367
Cadman
56 GMC
1922 Dodge Rat Roadster
89 Gray Allante
90 Red Allante
Turkey Run Photographer http://www.turkeyrun.com/photo_gallery.html
cadman89 is offline   Reply With Quote
Old 03-10-2006, 02:11 PM   #12
jollyroger
Re: frame swap ?
I used a 74 blazer 4X4 chassis on my 58. The only problem with using the late model stuff is track width. Kinda makes the tires stick out too much. I did graft a late cross-member on a 53. I cut and narrowed the crossmember to get the wheels and tires under the fenders to fit right. Sorta looks goofy otherwise.
jollyroger is offline   Reply With Quote
