Old 04-24-2005, 10:13 AM   #1
tnblazerk5
User #12137
tnblazerk5's Avatar
need pic of v8 4x4 motor mount stands
i just got the 4x4 v8 crossmemeber now i need to know what the motor mount stands look like so i can hunt those too and how they hook to the crossmemeber ? or is the 2 wheel drive ones the same ?
this is for 67-72 truck
tnblazerk5 is offline   Reply With Quote
Old 04-25-2005, 04:09 AM   #2
tnblazerk5
User #12137
tnblazerk5's Avatar
am i missing sumthing here ?
Old 04-25-2005, 08:14 AM   #3
jlhusa1
What exactly are you trying to do? What trans/tranfer case are you using?
jlhusa1 is offline   Reply With Quote
Old 04-25-2005, 10:53 AM   #4
tnblazerk5
User #12137
tnblazerk5's Avatar
i am making a 2 wheel drive into a 4 wheel drive and i just received a 4x4 v8 motor crossmemeber how does the motor hook to the crossmemeber? i need a pic of the motor mounts on a v8 4x4 truck please and if it makes a differance its going to be a 350/465/205 in a 1 ton truck
Old 04-25-2005, 11:12 AM   #5
ryanroo
ryanroo's Avatar
you can use the 2wd rubber pads for your 4wd conversion i think(never had a 2wd), they just bolt to the engine like normal and then a short like 1 inch long 7/16" bolt with a big washer goes through the holes in the x-member and into the rubber pad that bolts to the engine. i think they are all the same. sorry no pictures but i hope this helps
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-25-2005, 02:10 PM   #6
tnblazerk5
User #12137
tnblazerk5's Avatar
Ryan
yea that helps alot thanks !!!!!!!!!!! it means i dont got to buy anything else to put the motor in lol
Old 04-25-2005, 02:57 PM   #7
Russell
Professional Grade
Russell's Avatar
Actually, the brackets that bolt to the engine are significantly different between a 4x4 and a 2wd truck. However, the engine mount cups are the same, and you should have the towers.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
