Old 04-24-2005, 11:48 AM   #1
k5keith
np 205 pricing help
i have a good used np 205 and a guy inquired locally. but i have no idea of the value. it needs gaskets and maybe seals but works good. i'm in oregon . is there a difference between 1/2 ton and 3/4 ton np 205's ? thanks keith
k5keith is offline   Reply With Quote
Old 04-24-2005, 12:48 PM   #2
4bynut
4bynut's Avatar
The difference is what trans was in front of it. If it had a TH350 in front of it then that's all that will attach to it without changing the input. As for price it will depend on if you sell it by it's self (about $100) or with adapter and shifter ($150 - $225). Hope this helps. Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans.
2001 Chevy ZR2 Ext. cab 4x4 (DD)
1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process)
1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project)
4bynut is offline   Reply With Quote
Old 04-24-2005, 12:54 PM   #3
k5keith
thanks jason it finally stopped raining here so i crawled under the truck and the blazer to check it out. output shafts for drive lines are beefier on the 3/4 ton. both have t350's
Old 04-24-2005, 01:46 PM   #4
Americanrider
I recently paid 200 for a divorced 205 w/shifter & mounts from a guy in Woodburn Oregon and I think that was a bargain. Last week a th350 to 205 adapter sold for $153 on E-bay. I was watching to see the value because I might sell one that I have. I've seen 205's in the 250-300 depending on condtion and setup.
Good Luck with your sale.
Americanrider is offline   Reply With Quote
Old 04-24-2005, 02:29 PM   #5
k5keith
thanks boone i was thinking 250 for all. adapter broke and has beed welded but i have wheeled it for years and no problems. but $ 200 sounds fair
