Old 04-24-2005, 12:50 PM   #1
Nima
Blue 67
CD player connection question
Hi guys/gals:
First of all, I hope you have a good weekend. Well, fun continues. I draind my battery last night when I left my CD player installation incomplete!. I believe after I got confuse about wiring, I didn't disconnect my partial wiring and to make it worse, I left my ignition in! too.
Anyways, Can anybody tell me if I have to connect the yellow wire too? Based on the manual , yellow wire is battery wire which suppose to be connected to some where in fuse box. If that is correct, where in fuse box? Last night, I simply connected the red wire to radio connection on the fues box and the black one to ground but nothing happened.
And finally, Is the inline fuse for red wire (that one is from previous radio)as you see in the picture, suppose to be there? and if yes, what amp is it or suppose to be?
Thanks.
Nima is offline   Reply With Quote
Old 04-24-2005, 01:37 PM   #2
Striker169
Car O'Holic
Striker169's Avatar
Yeah the yellow wire is your "memorry" battery and it needs to be connected to an allways hot fuse or well what I did was run a wire directly to the cab from the battery, it has a verry veryy small drain on the battey just enough to keep your presets saved in the headunit and yeah the red one goes to radio fuse because it is a fuse that is hot on run and acc
Striker169 is offline   Reply With Quote
Old 04-24-2005, 02:11 PM   #3
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
the red wire needs a switched power to turn your radio on and off with the ignition, and the yellow needs a constant. as far as the inline fuse, every one that i have seen was stamped with the correct amperage. if you cant find it i would probably go 5 or 7.5
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 04-24-2005, 06:11 PM   #4
Nima
Blue 67
thanks guys.
Old 04-24-2005, 08:25 PM   #5
RED72blazer
urban fourwheelin
RED72blazer's Avatar
The fuse block has a constant hot area to connect for a radio
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 04-25-2005, 07:38 AM   #6
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I did the same thing with my first CD player. I always wired my cassette players so I could play them without the key (a habit from my old drinking days!) but that doesnt' work with the CD as I quickly found out. Only the memory wire gets constant power as mentioned above.
Bob
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
