04-24-2005, 03:53 PM | #1 |
85 K5 power window switch
if you pull the switch, it plugs into a small harness that the wires fit into...where can i find that harness (holder) ive been racking my brain trying to find one. cant locate it online cause i dont know the exact part name. HELP!!!
85 Blazer K5, 350- 4bbl 3:73 gears, 3 in sus. lift, 2 in body lift, 35's "While the Wicked stand confounded, call me with thy Saints surrounded" "Why dont you just sit there and bleed awhile, before you taste some real pain" |
05-02-2005, 09:09 PM | #2 |
What can I do next ????
harness
I had the same problem, the local junk yards is going to be your best bet and you can splice it in. also if you do splice make sure you solder it in place insted of butt splices they break down and get hot and come apart. found out the hard way
