04-24-2005, 06:23 PM | #1 |
Auto Columns
Is there a difference between the 67-68 auto columns compared to the 69-72's? I'm converting my wifes '69 from a 4-speed to an auto and might have a good line on a 67-68 column.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
04-24-2005, 06:32 PM | #2 |
The 67-70 columns used the same shift indicators and pointers, but the 71-72 style was different. I think they were taller and the indicator was made of plastic instead of chrome.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
04-24-2005, 06:57 PM | #3 |
They should fit 67-72. You will need to do somthing with the netural saftey switch. The reverse light switch should be the same thought.
Later , Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
04-24-2005, 07:54 PM | #4 |
Column
The 67/68 columns usually had a 1 piece shaft also, but you can use the shaft out of the other column if you like.
04-24-2005, 09:08 PM | #5 |
Personally I would stay away from the one piece shaft style from 67. If you're in a bad crash that crumples the front of the truck, I can picture the column pinning your head against the back wall of the cab.
I'm not totally sure, but I think the shifter lever on an automatic column was a little bit narrower where it is pinned in on the eariler columns. |
04-24-2005, 09:33 PM | #6 |
That's what I needed to know, thanks guys.
