Old 04-25-2005, 05:51 AM   #1
the baron
the baron's Avatar
steering column upper bearing question
Hi Guys ,
I'v just asked to my habitual dealer if the upper bearing for a 1982 tilt steering column are still available...
if not , has anyone any idea or experience in these , are they standard ball bearing available everywhere , and is the bearing used in a standard non-tilt column the same as in a tilt one ( still have a non-tilt column with a good bearing in it ) ?
many thanks ,
the Baron
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016
1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D.
1960 Girl Friend , frame still good , body has some dents
the baron is offline   Reply With Quote
