Old 04-25-2005, 04:55 PM   #1
chevy4x4girl
A dumb question
I know this is a lame question that I should know the answer to but oh well. I have an 84 GMC with part time 4wd (its got the lever that says 2h, n, 4h, 4L). Is the front driveshaft supposed to spin in 2wd? I thought it was only supposed to spin in 4wd. I cant tell if my 4wd is working because the light for it on the dash is burnt out. Thanks
'84 GMC K10 diesel
'02 Chevy Camaro SS collectors ed.
'91 Chevy Cavalier Z24
http://members.cardomain.com/chevy4x4grl
chevy4x4girl is offline   Reply With Quote
Old 04-25-2005, 04:59 PM   #2
Mudder
Mudder's Avatar
It is not uncommon for the the front driveshaft to turn some on a part time truck. Oh and we do not have dumb questions here. You may want to check both of your hubs to see if they are locking and unlocking. If one isnt working properly it could cause the shaft to turn.
Mudder is offline   Reply With Quote
Old 04-25-2005, 05:01 PM   #3
chevy4x4girl
How do I check the hubs? They are electronic ones obviously
'84 GMC K10 diesel
Old 04-25-2005, 05:07 PM   #4
uncle_handsome
Uncle H. is this cartoon
uncle_handsome's Avatar
This might not be your problem, but a lot of people who are somewhat serious about 4wheelin' like to replace the electric hubs with manual ones. If you want to do that it should be cheap.
uncle_handsome is offline   Reply With Quote
Old 04-25-2005, 05:19 PM   #5
Mudder
Mudder's Avatar
Are you sure they arent automatic hubs?
Old 04-25-2005, 05:48 PM   #6
1FaastC10
1FaastC10's Avatar
im going to assume that when she said electronic, she meant automatic. is there such a thing as an electronic hubs? i dont think i've ever seen any on a GM truck.
1FaastC10 is offline   Reply With Quote
Old 04-25-2005, 06:35 PM   #7
Mudder
Mudder's Avatar
My 86 had automatic hubs. I got rid of them fast. She'll be back.
Old 04-25-2005, 07:14 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
To add a bit to Mudder's reply about the front DS spinning in 2WD, it will be a slow, lazy spin caused by parasitic drag in the front diff. It will not be spinning nearly as quickly as the rear DS as you drive. If you can have a friend look under your truck as you drive by, the difference wiil be obvious. If the front is spinning as rapidly as the rear, it may be a stuck hub or two, or the transfer case might be in 4WD mode instead of 2WD.
Good luck - let us know what you find!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 04-25-2005, 09:09 PM   #9
chevy4x4girl
Well my trucks before had manual hubs so I didnt know much about the automatic ones. I drove it in reverse and the put it in 2wd and the hubs unlocked. Since I just bought this truck they must have been locked from being put in 4wd before I bought it. I would like to convert them to manual when I get some money. I had warn hubs on my 85. Anyhow thanks for the replys.
'84 GMC K10 diesel
Old 04-25-2005, 09:40 PM   #10
Mudder
Mudder's Avatar
I would change the autos to warns.
