Hey ya'll, Watch this!
DIY Wiring Harness: Where can I get the connectors?
I am interested in making my own wiring harnesses. The wire is easy enough to come by.
Anyone know where I can get the various connectors I need. I am looking for connectors for the headlamps, bulkhead connectors, and the ignition switch, and many others too numerous to mention. Hints or tips would also be appreciated?
Rick M. 72 GMC SWB Fleetside 25 Chevrolet Superior Series Truck 95 Mazda Miata 06 Dodge Charger RT http://ram92.ods.org/blog.html |
Designated A-hole!
Moved this so you'll get better response.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
the connectors alone will probably cost you as much as buying a complete hardness. and thats if you can find them all. lots of various pigtails are available in the help section of the auto parts stores
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Lovin' Life in Miss.!
I am interested in this also. Mainly the bulkhead connector terminals.
The truck... you hear that? No really, you did hear that?!!! |
Questionable
Bulkhead terminals are available at NAPA. Go to the FAQ thread and scope out my HEI post - pictures of the bulkhead terminals are there, along with pictures of the catalog @ NAPA which has them and the NAPA part numbers. HTH.
NAPA part # 725145 Cost is around 30ยข/each Here's a direct link to the catalog pages and stuff: http://67-72chevytrucks.com/vboard/s...2&postcount=28
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 04-26-2005 at 11:12 AM. |
Shifty, those terminals are not for the bulkhead fuseblock. They are for nearly every other connector on the truck. The catalog pic looks familiar...
Questionable
Oh yeah, that's right - you posted that for me originally, didn't you
![]() I really appreciate it. You helped me prove NAPA dude wrong. I had the biggest **** eating grin on my face when I showed him pictures scanned from his own catalog and he realized the customer was right for a change. ![]()
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Chickenwing helped me with that too. Now I've got a box of those connectors!!
A few weeks ago my dad gave me some odds and ends he was going to throw out. Carquest sells the connectors also, including the plastic casings/housings for the metal connectors to go into. They've got all sorts of pigtails already made. So if you need some connectors, chances are that they have those too. |
Assuming your considering fabbing all new harnesses from scratch, that'd be one hell of a job, especially locating the correct (new) connectors. A fella could reuse old connectors salvaged from several original harnesses, and maybe, just maybe find the correct contacts to rebuild them. The logistics are prohibitive on such a project unless you really like futility and frustration. I'm an electrician, and personally would much rather spend the money on a new set of harnesses.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() Last edited by Sweet72; 04-26-2005 at 09:16 PM. |
