Flushing Engine
I am in the middle of a waterpump swap out. What would be a good way to flush out the engine of all of the water and antifreeze?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Take out the 2 plugs just above the pan rail on each side of block. This will drain the block of all water.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Got Light Emitting Diode?
might have to poke out some rust, but she will flow
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler Last edited by 68w/sbc406; 04-25-2005 at 11:04 PM. |
#4 | |
they are two threaded plugs on each side. not the pressed in freeze plugs
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
Ok now I gotcha. So let me ask you this. Once I drain all this out how could I rinse out any litle pieces of junk that is left in the engine? Any suggetions?
#7 | |
#8 | |
Car O'Holic
#9 | |
#10 | |
