Old 04-26-2005, 05:49 AM   #1
conman
My Fuel Gauge Don't Work
I did a body swap putting a 70 model body on my 72 model chasis. I put the fuel tank from the 72 and also the gauge cluster. Before the swap the gauge worked perfect. Now, the gauge reads almost a 1/4 turn low. I know the wire is not broken. The only difference is the wiring harness plug-in on the 70 body had a total of 11 contacts,( 6 on top, 5 on bottom) the 72 has a total of 12 ( 6 on top, 6 on bottom) I cant figure this one out.
Fayette Alabama
conman is offline   Reply With Quote
Old 04-26-2005, 06:13 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The harness is still a 1970 harness, right?
Was it a dummy light cab or acc guages cab?
Old 04-26-2005, 06:33 PM   #3
conman
It was a dummy cab originally.
Fayette Alabama
Old 04-26-2005, 08:03 PM   #4
Longhorn Man
if it is still the dummy light harness, you probably already fried the fuel guage.
They were not wired the same.
When i did this, the needle on the fuel guage spun around a few times and gave up the ghost in a puff of smoke.
My buddy found it funny...I was less than amused.
Old 04-26-2005, 09:10 PM   #5
Gary Lee
fixer of 72 GMC LWB
A real long dowel or stick works well as a kinda dip stick... You just have to member to check it though...
I was just funning, but unfortunately as a GA resident, I have witnessed it... but it was dodge, what can i say...
Gary Lee is offline   Reply With Quote
Old 04-26-2005, 10:59 PM   #6
Longhorn Man
use a clean broom stick, less chance of somethign falling off the stick, and it is long enough to reach the bottom of the tank.
Like I said...been there....done that.
