Old 04-26-2005, 06:01 AM   #1
truck69
Question about POR 15
WHat is the easiest or only way to put POR 15 rust preventive and put it on the underside of my truck? I have a 69 chevy custom camper and want to put this on. So far people have told me use a brush. Do I need to prep the underside at all or the areas I will be putting it on? The truck is not disassembled so I would have to lay on my back. Any ideas would be great.
Thanks. Truck69
truck69 is offline   Reply With Quote
Old 04-26-2005, 07:44 AM   #2
Woody
truck69,
POR-15 requires a lot of prep work, but it works well in the long run. It does brush on well.
It requires 1) Cleaning surface of grease and dirt.
2) preping surface with Phosporous (sorry I cant spell) to eat rust (must be kept wet for 20 min)
3) 2 coats of POR-15 (a little goes a long way)
Step 2 is a real pain in the butt. POR-15 is NOT UV protected so it will fade, but being on the under side that should not be a problem. I would also cover it with an undercoating anyway so that part isn't a problem.
Woody
Woody is offline   Reply With Quote
Old 04-26-2005, 08:49 AM   #3
chevyfarmer
chevyfarmer's Avatar
I used POR before and the quote about it not being UV proof could not be more true. It literally faded and peeled off in sheets in the wheel opening where you would not think that too much sun would get. But I do agree that it does stick well in other areas. I would seriously consider removing the box to do this though, it will be a huge pain in the..... with that acid and POR dripping in your eyes. Best of luck.
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
Old 04-26-2005, 10:58 AM   #4
shifty
Questionable
shifty's Avatar
Don't use POR-15. Use Eastwood Rust Encapsulator. It's a one-step application, won't peel like POR-15 does if you don't do everything perfectly. It's also cheaper, you can brush it on, spray it on or use rattle cans.
http://www.eastwood.com/jump.jsp?ite...ORY&itemID=372
There's a good independent comparison of POR-15 vs Eastwood Rust Encapsulator here:
http://www.eastwood.com/jump.jsp?ite...88&iSubCat=852
I've seen a couple of the other guys in the bodywork/painting forum who agree ... Eastwood's product is better for most applications.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-26-2005, 12:53 PM   #5
truck69
Thanks everyone for the info.
Truck69.
