71 Cheyenne SWB Fleetside
does anyone know if there is a single piece drive shaft out of a newer truck that would fit a SWB 71 truck with a TH350 engine? dont want to pay loads to have one made. will have to change the yoke im sure. but is there any other option then having one built?
thanks joel
![]() Join Date: Nov 2004
Need some more info. What happened to your driveshaft? Is it a two piece? I was under the impression SWB trucks all came with a one-piece? Did you use something other than a GM rearend? If you need your driveshaft shortened, I had mine done for $15 at a local shop. If you need it lengthened, I see your dilemma. Go to a 'yard and start measurin
![]() Edit, when I put a 700R4 in my truck I had to find an automatic splined shaft so I thought, why not try to find one that will already fit, not sure on your tranny lenght, but trips to 3 yards didn't come up with a match. I ended up adding the automatic yoke and takin it to a shop.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 04-26-2005 at 05:29 PM. |
#3 | |
my gas saver
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
hey Redneck,
the one in the truck is a two piece unit and the hanger bearing is toast. so i just thought maybe i will get a single piece, rather go that route. its the standard 12bolt truck rear end. TH350 with a 350CI engine. on a SWB fleet side truck. Chevye, are you looking to sell one of those single piece units you have there? if so, how much and pics? i thought maybe i could go with a SWB newer style truck with those aluminum ones? joel
my gas saver
i can't sell mine, i need em. i know "suicideD" had one for around $50 or so. just put a wtb ad up and i'm sure someone will reply. i have had driveshafts done for v8 s10's before for around $140. it would probably cost $100 to ship one from here to there anyway.
![]() check with "billsbowtie" also, i got both of mine from him. he always has a ton of parts.
its all about the +6 inches
If your engine and tranny are installed in teh proper location on the frame, the drive shaft will need to be 4 foot 10 inches....first gen Camaro/fire bird (F body) had the same, and that would make me wonder about the 78 - 72 ( I think I got the years right) Nova and clones (X body) since the under pinnings were pretty much the same.
thanks guys,
im going to put up a wanted add for now i guess see how that goes. how does that work now, with a single shaft when your rear suspension moves will there be enough room in that centre cross member where the shaft passes through? worried about it hitted the top of it if you hit bumps or something? let me know. joel
longhorn, a newer short box truck shaft wouldnt fit eh?
joel
joel
no clue Joel. Never had to measure one. I wouldn't do the late model ones though becouse the stupid GM U-joints pretty much blow, and the replacements never seem quite right...you have to drop the shaft to lube it...so it never gets lubed.
alright thanks for you help
joel
I have never seen a swb with a two piece. Interesting. I'd call around to some local yards to see if they have a one piece. As far as I know you shouldn't have any problem with the center section hitting the shaft unless yuor truck is seriously lowered. Make sure it's for an automatic and you may have to still measure, I think some tranny's were different lengths back then??
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#13 |
'68 C10 SWB/FS 396/TH400
FYI, my '68 SWB/FS 396/TH400 has a two piece shaft.
'68 Custom/10 w/396/TH400 matching #'s '00 C3500 Dually 454 Crew Cab '99 Chevy Tracker 4x4 (1 tuff little muther!) |
#14 |
two piece sucks, thats why i want to chang mine. the hanger keep going.
![]() Last edited by joelboxt; 04-27-2005 at 09:21 PM. |
#15 |
my gas saver
hey joel, i'll measure one in the garage when i get home if you need me too. it might help you out looking for one.
#16 |
1 pc. driveshaft
I used one from a 1966 Chevelle.
I had a custom one made for my 66 chevelle from dennys driveshafts. The original one from the chevelle was a perfect fit in my 71 short bed with turbo 350. The chevelle is a big block with muncie 4 speed. Much smoother and quiter than the 2 pc. shaft. |
#17 |
One thing to remember...a properly ballanced drive shaft, with all the u-joints and carrier bearing installed properly, will not only last for many years, but will hold up to gobs of power. If it is time to redo everything...all the joints and bearing, then it may be a good time to replace it...but IMO, it is a bit of a waste of $$ to replace the assembly when nothing is wrong.
I only say this becouse WAY too many ppl think that a 2 pc shaft is unsafe or a maintnance nightmare. |
#18 |
chevye, i would appreciate it.. let me know.
thanks, joel
![]() Last edited by joelboxt; 04-27-2005 at 10:58 PM. |
#19 |
longhorn, i dont think they are unsafe. but the hanger bearing is toasterd so id like to maybe lose the two piece.
joel
#20 |
Chevye...the one from the GMC is 4 foot 10 inches...the rear U-joint is a couple years old, front one is pretty old.
#21 |
i used a one from my 86 chevy caprice with 700 tranny still have it on there Riddla
68 GMC-Stripshow 70 Chevy Monte Carlo 72 Chevy Monte Carlo LOLO 72 Chevy Suburban Blurban 74 Vw Bug 78 Chevy k10 lwb 78 Chevy k10 swb 03 Cadillac Escalade-Duecesix 84 Cadillac Coupe Deville DeElegance ![]() ![]() B.O. A Lifestyle Money Cant Buy! Win,Lose, or Tie I'm a Raider till i die |
#22 |
![]() Join Date: Jan 2001
Location: Katy, TX...but the love of my life resides in Dublin,OH.
I do have one, but mine was with the v-8 in the six cylinder position. Might not work for the standard configuration. I had to go look at my for sale page to remember how much I was asking.... I'll take 75.00 plus shipping.
http://www.suicided.com/forsale.htm Thanks ChevyE for pimpin my stuff.... got a door skin installer I'll let you push also. Last edited by Suicide-D; 04-28-2005 at 07:33 AM. |
