Old 04-26-2005, 06:09 PM   #1
joelboxt
71 Cheyenne SWB Fleetside
joelboxt's Avatar
Exclamation search
I see the search is gone again?
joel
joelboxt is offline   Reply With Quote
Old 04-26-2005, 06:27 PM   #2
HeavyD
HeavyD's Avatar
Looks like it
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 04-26-2005, 06:41 PM   #3
shifty
Questionable
shifty's Avatar
Looks that way. It may or may not be any help, but ... you can use this link to search *only* the forum and the 67-72chevytrucks.com website if you really need it:
http://www.google.com/custom?domains...hevytrucks.com
It's basically a link to a customized google which isolates this website alone.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-26-2005, 06:58 PM   #4
Mudder
Mudder's Avatar
Josh has the search turned off for the time being.
Mudder is offline   Reply With Quote
Old 04-26-2005, 09:44 PM   #5
joelboxt
joelboxt's Avatar
hey thanks shifty.
may i ask why it gets turned off all the time? does it use alot of bandwidth or something?
just curious.
thanks,
joel
Old 04-26-2005, 11:18 PM   #6
shifty
Questionable
shifty's Avatar
I can't speak for Josh, but ... I recall he was saying something about MySQL optimization.
When you have a forum with hundreds of thousands of posts to parse in several tables (I'm assuming each forum has its own table of fields/rows/columns however you want to think about it), it obvious takes some CPU processing power to take care of it.
He's dealing with exams right now IIRC. The search feature was probably bogging down the server (remember the slowdowns last night? ugh!) and he turned it off again.
I've been so busy I haven't been able to read up on MySQL optimization. Meant to help with that, life has just been uber stressing. Maybe I can do it after surgery in the next week.
