Old 04-26-2005, 09:35 PM   #1
68nuke
Steering questions
Hi. I have a 71 k5 cst that has some seriouysly loose steering. Is the gear box the same for a k5 and a c10 if both have power steering? Thanks!
68nuke is offline   Reply With Quote
Old 04-26-2005, 10:53 PM   #2
donkey69
JB-80 "Twice as Good"
donkey69's Avatar
4x4 steering boxes should be the same,Blazer and pickups.......a guy might want to check where the bolt holds the column shaft to the shaft on the steering box-mine was loose on one truck right after I bought it and the truck wandered bad. Oh yeah.....and Welcome from MN!
HEY NOW!
donkey69 is offline   Reply With Quote
Old 04-27-2005, 11:38 AM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Check the rag joint too. I've heard they can cause wandering, etc, if they are worn.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-27-2005, 01:38 PM   #4
DruBlazer
Got Blazer?
DruBlazer's Avatar
Welcome to the board.
There are a few easy things to check in your steering before you replace your box. When I bought my blazer the steering was bad too...Like 2 lanes bad. It was a combonation of the rag joint, the steering box, and two ball joints. After the rag joint and the ball joints were replaced, I was able to live with a little slop in the box. Have someone in the cab turn the wheel as you look around underneath for what may be causing the problem.
Good luck.
DruBlazer is offline   Reply With Quote
Old 04-27-2005, 05:18 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
2 THE BOARD FROM WEST 10-UH-C
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-29-2005, 07:21 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Welcome to the board best of luck on your steering woes
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-02-2005, 12:16 PM   #7
68nuke
Thanks for the suggestions guys. I'll check it out and let you know what the problem is.
Old 05-20-2005, 12:52 PM   #8
68nuke
I figured out the problem.. It seemed to be a bunch of things. My gearbox had a lot of play in it, my rag joint was worn out, and the u bolts holding the front axle to the leaf springs were loose on the driver's side. The front end had a centimeter to movew on the driver's side!
68 C-10 Longbed - LT1/4L60E
71 K5 CST 350/350/205
Never again volunteer yourself!
Old 05-20-2005, 05:42 PM   #9
DruBlazer
Got Blazer?
DruBlazer's Avatar
Yup. Sounds like an old truck to me. I'm glad you found it. That sounds a little unsafe.
Old 05-22-2005, 08:42 AM   #10
70cst10
It's much better now! I think I might still have to change the gearbox, because there's quite a bit of play in it, but it's good for now. Thanks for the input!
Milan
1964 Chevelle SS 283/M20
70cst10 is offline   Reply With Quote
