![]() Join Date: Jan 2001
Energy Suspension Urethane Cab Mounts To Trade
I have a set of unopened Energy Suspension black urethane cab mounts for a 1/2 ton and would like to trade for a set for a 3/4 ton.
Thanx! Bud ![]() Last edited by 69sixpackbee; 04-27-2005 at 12:54 AM. |
Excuse my dumbness...
![]() What's the difference between the two? I just saw a post the other day saying the only change between a 1/2 ton and a 3/4 ton was the axel set. ![]() Why would the cab mounts be different? Bump for ya. Last edited by vtblazer; 04-27-2005 at 06:19 AM. |
The cabs are the same, but the 3/4t's and 4x4 frames are different that allow a thicker rubber mount.
Marysville, WA (Dan72cst@hotmail.com) 72 4wd Blazer CST 350/350 72 4wd Chevy LWB 350/350 68 2wd Chevy LWB 327/400 |
I can tell that the rear upper cushion is thicker than the 1/2 ton one not to mention the lower rear cushion is really longer plus the bolts are as well.
Got Big Block?
if you don't find a set for trade, what do you want for them?
"Experience is what you get when you didn't get what you wanted." |
It's right here:Urethane Mounts
Thanx! |
#7 | |
its all about the +6 inches
#8 | |
I had read it on another thread and was curious, thanks for clearing it up. |
