Old 04-27-2005, 01:57 PM   #1
twitch4187
Limited Slip To Posi
Ok here's the deal I bought a 68 Chevy Stepside about a week ago. I know it has a limited slip rear end but I want a posi unit. I plan to swap the engine to a 383 stroker and I need it to be strong. Do I need another posi axle or will a Detroit Locker or Eaton Locking unit work? Does anyone know the part numbers or where I can get these lockers? I have to be able to order from the internet since I am currently deployed in Iraq.
twitch4187 is offline   Reply With Quote
Old 04-27-2005, 02:04 PM   #2
FirstGen
Just Don't Stop!
FirstGen's Avatar
a limited slip is commonly referred to as a "posi". The Eaton unit you are talking about are limited slip units and the detroit locker is actually a locking diff. If you are wanting to upgrade to a newer and stronger limited slip unit I would reccomend the Eaton. It is very durable with it forged spider gears and heavy springs and carbon clutches. It is also fully rebuildable with several upgrades. You can get them through Jegs or Summit or also find them online on ebay and such.
Goodluck and WELCOME!!!
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 04-27-2005, 02:05 PM   #3
Purs
Got Big Block?
Purs's Avatar
limited slip is just another term for positrac. Lockers on the other hand are different. Check out this site for good info:
http://randysringandpinion.com/conte...lt.asp?pid=128
just noticed that FirstGen beat me to it!
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 04-27-2005, 02:10 PM   #4
FirstGen
Just Don't Stop!
FirstGen's Avatar
haha I win
TT LSA/6L90e/9"
Old 04-27-2005, 02:23 PM   #5
Purs
Got Big Block?
Purs's Avatar
you must have been "on the juice"!
Old 04-27-2005, 02:35 PM   #6
twitch4187
great info guys. Would an ARB Air Locker stand up to the punishment in your opinions?
Old 04-27-2005, 02:40 PM   #7
Purs
Got Big Block?
Purs's Avatar
I'm with FirstGen, I'm going through my 12 bolt right now and I chose the new Eaton Unit. The internals are darn near bulletproof AND rebuildable if you do happen to trash it....
I have no experience or knowledge about the air lockers.
Old 04-27-2005, 02:44 PM   #8
twitch4187
Thanks guys I'll look into the eaton unit.
Old 04-27-2005, 02:55 PM   #9
smokekiki
Mike
smokekiki's Avatar
I have seen ARB's take some punishment without failing.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 04-27-2005, 03:03 PM   #10
Jason915
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
This locker is awsome for traction and very tuff, I broke an axle shaft with this locker and the locker held up just fine.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 04-27-2005, 05:49 PM   #11
CHEVIBUBBA
got boost?
CHEVIBUBBA's Avatar
the airlocker will hold up beyond what the rear will take if install is correct.
according to peyton performance in waxahachie TX. the truck 12 bolts will hold up pretty good into the 13's.the pinion gear shaft is smaller than the car 12 bolt,(why?),so much more than that & it's KABOOM!
'70 chevy lwb w/'67 hood.
357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada.....
'82 honda v45 sabre"the black"
CHEVIBUBBA is offline   Reply With Quote
Old 04-27-2005, 06:09 PM   #12
FirstGen
Just Don't Stop!
FirstGen's Avatar
Actually the pinion shaft is not the weak link. These truck rears have seen many many cars/trucks in the 10's and even 9's. The weak point in the Chevy 12 bolt/14 bolt design is actually the contact pattern on the ring gear. With more than around 750 horse you will actually strip the ring gear teeth off the ring gear. Remember that the pinion is a very short piece of metal and quite large in comparison to say your input shaft on your tranny which is smaller in diameter and longer to boot. Another point is that the pinion is being applied before you multiply torque because of the actual ratio.
Many board members have been into the 11's on the truck rear, myself included.
TT LSA/6L90e/9"
Old 04-27-2005, 06:11 PM   #13
FirstGen
Just Don't Stop!
FirstGen's Avatar
I destroyed one of these... They also do very weird things in race applications. Say you get some wheel hop, these have a tendency to un-lock on you. I think the Eaton is the best bang for the buck...
TT LSA/6L90e/9"
Old 04-27-2005, 06:16 PM   #14
BubbaGreen
I went with an EATON as well....3.73gears in the stock 12bolt axle.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 04-27-2005, 07:26 PM   #15
CHEVIBUBBA
got boost?
CHEVIBUBBA's Avatar
realy!thats my dream!actually, it's 10's but....
ever hear of a LWB doin 11's?
how much did yours weigh when you broke into the 11's?
guess i need to get the lowdown on your truck!
good to know it's been done on the stock 12bolt.
i stripped a ring gear last year.not 750 horses though.about 450.
more due to wear than power i think.
Old 04-27-2005, 08:54 PM   #16
FirstGen
Just Don't Stop!
FirstGen's Avatar
I weighed in at 3600# with out me in it. This was before I chopped it down to a short wheel base. It takes about 750 horsepower and 3500# to strip the teeth on a new set of Motives or GM gears - being tight and properly set up is a must. After that you can go to the pro series gears but you can't run them on the street because the will wear out quickly.
I went 7.50's on 125 shot when I was long wheel base. That's mid/high 11's. It should do that on the motor now and 7.0's or 6.90's on the spray...
TT LSA/6L90e/9"
Old 04-27-2005, 09:00 PM   #17
jamesi20
jamesi20's Avatar
You should maybe look into the TRUETRAC it is a gear driven limited slip that from everything I have read and seen is basically bullrt proof.I had one put in my 12 bolt by a guy (John Peto) who is a NHRA record holder and he swears by them.They are very street freindly and according to John lock up good at the strip.just my .02worth
www.tractech.com
jamesi20 is offline   Reply With Quote
