Old 04-27-2005, 07:13 PM   #1
Paradise Ridge
Paradise Ridge's Avatar
Question Manual Window Regulator Install
Howdy all,
Search is down and I looked through the FAQ's, but couldn't find anything on a regulator install.
Can somebody give me heads up on what it takes? It looks basically straight foreward, but it's been raining here daily and I don't want to get caught with the window out after hitting some unexpected problems.
Thanks!
Scott
Paradise Ridge is offline   Reply With Quote
Old 04-27-2005, 10:08 PM   #2
u2slow
Web Wheeler
u2slow's Avatar
I found it tricky to get into the door and onto the the windows track in one shot. Took a few tries. If you have it in, and not on the tracks, take it back out and try again. IIRC, wind the regulator to about 1/2-way first.
I converted my one door with a dead window motor to manual instead
'66 C10 longstep - Clifford equiped
'84 C20 Suburban 6.2L - awaiting 4x4 conversion
'91 V3500 Crewcab - awaiting diesel swap
u2slow is offline   Reply With Quote
Old 04-29-2005, 12:37 AM   #3
hotrodmtodd
'Burban Legend
hotrodmtodd's Avatar
CRUCIAL Info
THE main thing is, DO NOT remove the rivets from the motor unless you clamp it HARD or bolt it in place. The spring is VERY high tension, and you WILL lose fingers if you do not hold it in place first SECURELY. Trust an old Chevy Dealer body man who NEARLY found out the hard way. Be careful, Hot Rod
hotrodmtodd is offline   Reply With Quote
