04-27-2005, 09:26 PM | #1 |
Mandrel bent pipes
Does anyone know of a supplier for complete mandrel bent exhaust pipes for our trucks? I want a new mandrel bent system for my 1971 Chevrolet half ton Cheyenne with big block 402 with factory monifolds with the exhaust exiting in the factory location. Has anyone ever heard of a muffler shop that will do mandrel bending or are these an order only item? I don't need anything big or anything. Two and a half inch head pipes and two inch tail pipes is what it came with. I might consider two and a half inch tail pipes...
Any leads? Thank you.
Kevin Korff Evansville, IN 47711 1997 Silverado 3500 LWB Vortec 454, headers 4.11 posi. Victory Red WOW! 1976 Oldsmobile 98 Regency four door 42,000 miles original paint. This is still a car! 1990 Oldsmobile 98 Touring Sedan 34,000 miles 1983 Hurst/Olds 30,000 actual miles 2013 Ford Taurus SHO 1972 Hurst/Olds-a work with no progress 1972 Oldsmobile 442 Convertible 455 Last edited by 72skytop; 04-27-2005 at 09:36 PM. |
04-27-2005, 10:41 PM | #2 |
You shd have no problem getting mandrel bends from an exhaust shop without having to go too far. All of the custom shops (exhaust) in my city have the machine to do it. I had my system custom bent 2 1/2" dia. and requested aluminized steel pipe, I would have prefered the stainless but it was roughly twice as much $. Doug
04-28-2005, 01:04 AM | #3 |
i had mine build in cal, did not find any where in texas. mine are ss.
04-28-2005, 03:54 AM | #4 |
LMC Truck sells mandrel bent oem-style exhaust systems (dual V8, single I6) with mufflers. In the color pages. I've been trying to find out who makes those systems so I can look into buying them from the source or another distributor, especially if I can get them cheaper without the mufflers. I'm still stuck on going with a single V* system, though.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
04-28-2005, 07:20 AM | #5 |
i don't think anyone in the entire state of texas has a mandrel bender... i had to order my bends from summit and then make my own system..
https://www.ebay.com/itm/29620574751...mis&media=COPY |
04-28-2005, 09:01 PM | #6 |
I couldnt find anyone in my area eithor. I called like 25 places....
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
04-28-2005, 09:09 PM | #7 |
If you lived in the rust belt I'll bet you'd find someone with a mandrel bender.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
04-29-2005, 12:24 AM | #8 | |
i dont know where you live , but i order mine from bobs. http://www.bobsmuffler.com/mandrel.htm |
04-29-2005, 08:31 AM | #9 | |
I purchased their system for my truck from LMC. It was drop shipped to my door and fit my truck like a glove. I don't know why everybody gives LMC such a hard time. EVERY order I've made there was complete and on time. (I do NOT work for them or am associated to them in any way).
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
04-29-2005, 02:52 PM | #10 | |
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's 1970 K5 TBI conversion lifted etc SOLD 1968 C20 camper truck SOLD “To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder |
04-29-2005, 03:15 PM | #11 |
Blue 67
JC Whittney has a set too. I believe they come w/out mufflers. I remember I heard once that they are the same as LMC. I don't know how they fit, I never used them but I am thinking about it too. They are dual, 2.5'' diameter and exit on stock location. It ssaid in their catalog that it only fit with stock manifold. I hope this help.
04-29-2005, 05:47 PM | #12 |
The LuvShack Garage
Because I Worked Pt For A Muffler Shop 2000-03, I Can Tell
You Most Shop Benders Are "Not" Mandrel Benders, Mandrel Benders Leave No Drag Marks On The Bends, The Local Shop Here Can Get Them For Any Vehicle, For A Price, They Charge You $150 And Bend Up The Whole Truck In 1 & 7/8 Pipe, Then They Send That To The Distributer, Who Bends It In The Size That You Want And Sends It Back, Last I Heard It Was Run'n In The $350-$450 Range, So That's Like $500-$600 Total, And Like Above, That Is Aluminized, Not Ss, It Would Be Closer To A Grand For SS, That Is Why Mine Is Just Gonna Be Std. Bent Pipes, Aluminized, With SS Mufflers And Tips, Cya
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 04-29-2005 at 05:50 PM. |
04-29-2005, 07:02 PM | #13 | |
Señor Member
Dave Rash of D&D Exhaust (motorcycle stuff) in Fort Worth has a mandrel bender. Years ago he bent up some stuff for one of my drag bike hoopteys. I don't know how big he can go, though. The bike was 1.875Ø
04-29-2005, 07:49 PM | #14 | |
i will post a pic when i finish installing my pipes. fiy, $40.00 each pipe and there ss. a place in ny wanted $60.00 each and stainlesswork.com wanted $110.00 each. |
04-30-2005, 02:54 PM | #15 |
Location: Help! I'm in an office park with its own network of freeways!
I used to make mandrel bends at work. Too bad they closed the shop a couple years ago.
That said, most late-model cars & trucks now have 409SS, mandrel-bent exhausts. If you're so inclined, you could pull a couple exhausts out of the salvage yard. Mine was made of of a few obsolete '04 Durango tailpipes.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man) '95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis) '07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed* |
