04-27-2005, 09:49 PM | #1 |
Which Vent Window Is Original????
I have two trucks, one driver and one for parts. I went to replace the wing window today, only to find out that on each truck, the passenger side window has the handle on the wing frame, and both trucks have the handle thru the glass on the driver side! Which design is the way that they were made?
04-27-2005, 09:52 PM | #2 |
Resident Curmudgeon
Thru glass is 68-72. The other style is 67 only.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
04-27-2005, 09:54 PM | #3 |
TH400 vs. TH350 For driveshaft???
Hey Everybody!
I just put a SBC in my 67 using the 6 cylinder mounts, and a TH350 trans that was supposed to be a ""good"" one, but,,,,,,,,yep, it went to lunch before I put it in apparently! So, now I'm supposed to be getting a TH400 for it. What options do I have for the driveshaft/mounting using the 400 in it's place? I do have a spare set of V-8 mounts if needed and it's getting rodded so I can put what ever in for a crossmember, that doesn't matter. Please let me know your thoughts, thanks so much in advance. |
04-27-2005, 11:20 PM | #4 |
Thru Glass or Frame Vent!
Thanks, CPNE. I appreciate it.
