04-27-2005, 10:01 PM | #1 |
Free Parts Disc Question!
The other day a gentleman that has a '72 with front disc came into my shop and said he was swapping his front spindles for drop's and wanted to know if I wanted his old ones...I said sure!!! I have power drum on my '68...what is needed for me to make the swap. Do I need to change ball joints and tie rod ends or booster and master cylinder? Thanks!!
Douglas.
-1968 Chevy SWB = Frame Off/383/Muncie Car 4 speed -1968 Chevy SWB = numbers matching 307/Truck 4 speed. -1966 Chevy II = 2 door No Post/130,000 Orig miles/230 6cyl/powerglide/Vintage AC -1972 Chevy Nova = 2 door/412 Small Block -1927 Ford Roadster = Homebuilt/widened 8"/350/ Custom Everything. |
04-27-2005, 10:51 PM | #2 |
Ball joints, tie rod ends, adaptor sleeve for the later. Booster is fine, 71-72 master and P-Valve. Then of course you'll need rotors, calipers, pads and hoses.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
