04-27-2005, 10:17 PM | #1 |
new truck, new problems.
I recently got a 69 c10. The wiring in the rear was a mess. Nothing on the drivers side rear was working, and I had no brake lights right or left. I got a wiring diagram and got everything working EXCEPT the passenger side brake light. I can't figure it out. Any ideas? What color wire is supposed to be passenger-side brake?
Thanks for any help. Josh |
04-27-2005, 10:23 PM | #2 |
its all about the +6 inches
If the right side turn signal works, but the brake light does not, then the turn signal switch will be the problem.
04-27-2005, 10:25 PM | #3 |
yes, both turn signals work. Where is the turn signal switch? Would it have to be replaced or just fixed?
04-27-2005, 10:41 PM | #4 |
it is in the column...you'll need a steering wheel puller.
There really is no repair, it'll need replaced. |
04-27-2005, 10:49 PM | #5 |
Ok, thanks for the help.
