Old 06-11-2002, 11:31 PM   #1
Mountain Man
Removing dash bezel - Question?
I am changing my dash bezel for a new reproduction one. Last time I took my dash bezel out, I had a hell of a time getting the headlight knob out. Is there a release for the headlight knob rod behind the dash bezel, or do you just pull hard until it releases. I don't want to break anything.
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 06-11-2002, 11:34 PM   #2
Benrs86
Benrs86's Avatar
feel up in there and the back of the headlight switch is like a box, right on top there is a button, push the button, hold it down, and pull it out. good luck, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 06-11-2002, 11:43 PM   #3
Mountain Man
Smile
Thanks bens86, I thought that there must be a release for it somewhere. Appreciate the good info.
Full trim
Factory tach dash
A/C dash
Factory tilt
Old 06-11-2002, 11:48 PM   #4
Benrs86
Benrs86's Avatar
no prob, i learned the hard way
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
Old 06-12-2002, 04:04 PM   #5
rustfree
one other thing. You can't push the button down unless the knob has been pulled out one click (I believe) then hold it down and pull out the knob/shaft. Don't forget to diconnect battery
72 swb cheyenne super 350/350
69 cst20 BB longhorn
Warren, OR
rustfree is offline   Reply With Quote
