Life is a gamble
Alternator
I got an overwhelming response about Optima batteries being the best with my battery post. What does everyone suggest for an alternator?
Where to buy? What to look for? Thanks -Arthur
1970 Orange CST C-10 w/350, posi, Longbed The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine. -- Ralph Waldo Emerson |
blood type; Retumbo
go to the boneyard & find one from a 85 olds Delta 88. then have it rebuilt by an independant alternator/starter shop. I personally dont trust any that you can buy already done. (Westling is the worst)
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
Junior Member
I went with a one wire 100 amp from summit racing no troubles so far.
68 GMC 565 BBC Abruzzi super pro glide 9.85@135.00 ![]() |
Life is a gamble
Kwhite4, How long have you had it?
you can buy a 1 wire hook-up alternator at oreillys.
#6 | |
got boost?
'70 chevy lwb w/'67 hood. 357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada..... '82 honda v45 sabre"the black" ![]() |
I'd go with any internally regulated alternator capable of a minimum of 70 amps on a stock or near stock truck. I'd also recommend not using the 1 wire alternators.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
#8 | |
blood type; Retumbo
got boost?
hmm.ok.
any idea on the amp rating?
