04-28-2005, 07:55 AM | #1 |
Ground Wires. Where ?
It's been 4 year I cant remember where the ground wires go. I think one went on the pass side cab mount dont remember any where else.
Thanks for the help.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
04-28-2005, 11:29 AM | #2 |
Here is some pictures of a very low miles 72 truck that appered to be very stock and unrestored. It´s not my truck.
There was a ground wire on the passenger side only. Sorry, can´t help you with the rest of the ground wires.
Mats.. ---------------------------------------------------- 1971 Cheyenne Super Custom Camper 475CBB/TH400/AC 1992 Silverado Sport Truck 1988 Silverado 2500 Ext Longbed 4x4 2001 GMC Sierra SLT 4x4 1990 Chevrolet K3500 1965 Pontiac Grand Prix 1980 Z 28 350/4-speed/AC/T-top 1980 Camaro Coupe V6/3-speed 1979 Buick Century Wagon |
04-28-2005, 11:30 AM | #3 |
Drivers side
04-28-2005, 12:56 PM | #4 |
Cool Thanks.
That's one. Anyone know if there should be more ?
04-28-2005, 01:29 PM | #5 |
#16876
I have one from the exhaust manifold to the firewall.
04-28-2005, 01:55 PM | #6 |
2 - valve cover to firewall straps
1 - passenger inner fender to frame strap 1 - frame to passenger side front cab mount strap 1 - frame to rear passenger bed cross sill strap demi |
04-28-2005, 08:20 PM | #7 |
Demi,
Do you know which cross sill and which side of the truck the ground wire is on? Jim |
04-28-2005, 10:10 PM | #8 | |
From the frame to the 2nd from the rear bed cross-sill on the passenger side. This is from GMC Pauls. Demi Last edited by demi; 04-28-2005 at 10:14 PM. |
04-29-2005, 07:39 AM | #9 |
Demi,
Thanks! Jim |
04-29-2005, 09:12 AM | #10 |
Pic's took at night so not the best but should help you locate
2 - valve cover to firewall straps 1 - passenger inner fender to frame strap
1972 C10 SWB 350 / T400 1972 SWB GMC 350/T350 1972 Cheyenne 20 super "long horn". 402BB / T400 1972 Suburban C10 Deluxe 350 / T350 and a few more.. http://www.myspace.com/afew72s |
04-29-2005, 11:21 AM | #11 |
can you buy these straps at a local shop?
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
04-29-2005, 11:26 AM | #12 |
Bought mine from NAPA. Only a couple dollars each, and you can get different lengths.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
04-29-2005, 11:53 AM | #13 |
Progress = 0%
Since you aren't doing a "correct" restoration, you don't necessarily have to put the ground straps in the original locations. Just make sure you have grounds that connect the body, engine, frame, and battery. The engine and body are isolated from the frame (rubber body mounts, rubber engine mounts, etc) so ground straps are a must. I have one going from the engine to the frame and one going from the frame to the underside of the cab. Might also be a good idea to put one from the bed to the frame. The bed sits directly on the frame and therefore shold be grounded, but paint (and future dirt and rust) could prevent a good ground.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
04-29-2005, 12:01 PM | #14 |
for the cab one im using this...was 4.50 at hovis....
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
04-29-2005, 10:02 PM | #15 |
I second what slammed said. I got ground staps all over my truck. Some electrical stuff was actin "funny" when I put the truck together. So, I made sure everyting was grounded to the frame and shazamm, no more electric gremlins. It ain't factory, but everything works.
I got a bench seat baby, you don't have to sit over there. |
04-30-2005, 05:50 PM | #16 |
Thanks Guy's
I Got new ground straps like C10stepside showed. I put one from the frame to the cab and another from the bed member to the frame. I mounted my battery to frame behind the cab. Then I grounded the battery to the frame then grounded the motor to the frame. Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 04-30-2005 at 05:51 PM. |
