Old 04-28-2005, 10:27 AM   #1
qpjeffc
Simple gear ratio question
Just a quick question, are 4:11 and 4:10 ratios the same? I have heard a lot of differing opions on this so I thought you guys would know for sure. I have a 14bff that I want to install with 4:10 stamped on it and my front is 4:11? Thanks, Jeff
qpjeffc is offline   Reply With Quote
Old 04-28-2005, 11:25 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Not positive, but I am fairly sure they are not the same. I believe 4.10 has 41 teeth on the ring and 10 on the pinion, and 4.11 has 37 on the ring and 9 on the pinion. Since 4.11 has fewer teeth, they will be larger, and therefore stronger. At least that's what I recall hearing back in my old hot-roddin' days!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 04-28-2005, 11:52 AM   #3
Rod
Its not going to make any real difference ..theres usually a little difference between front and rear ratios anyway. Like a 4.10 rear with 4.09 front...or 4.57 rear with 4.55 front. Those are typical 67-72 truck numbers anyway. I take it your swapping the whole diff. You may run into problems trying to interchange different brand axle gears into different brand housings. You really didn't explain enough.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 04-28-2005, 03:12 PM   #4
1969 GMC
1969 GMC's Avatar
They are not the same, because they have different ring and pinion tooth count #'s.
The 14 bolt that I bought, for example, has 4.09 gears (45 on the ring gear and 11 on the pinion).
there are also the more common 4.10's which have 41 teeth on the ring gear and 10 on the pinion.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-28-2005, 03:34 PM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
Like said above, it is normal for the front axle to be slightly different than the rear axle. Like in my 69 K20, one axle is 4.56 and the other is 4.57.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-03-2005, 10:03 AM   #6
1969K10
1969K10's Avatar
Friend of mine has a Dodge Dakota, and there is a huge warning label not to drive it on paved surface. I was told the reason being, those trucks are set up with 4.10's in the front & 4.11's in the rear. that way when locked in, the front is always pulling, and the rear just has to keep up...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 05-03-2005, 11:38 AM   #7
Mudder
Mudder's Avatar
Its pretty common for theme to be a number off. A lot of mud racers like the front higher so that the rear doesnt try to pass the front.
Mudder is offline   Reply With Quote
Old 05-03-2005, 12:39 PM   #8
Jason915
Yeah typically you want your front to pull forward somewhat, like mudder67 said so the rear don't try to pass you up. Nothing wrong with running the same exact ratio in the front and rear 4.10/4.10 or 4.09/4.11, 4.10/4.11 just make sure that the higher ratio is in front.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
