Old 04-28-2005, 01:11 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Looking at A1 Electric Windows Any Input?
I'm considering installing the A1 electric windows in my truck. Has anybody had any experience with them? Any problems or recommendations?
http://www.a1electric.com/index.htm
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 04-28-2005, 02:26 PM   #2
Russell
Professional Grade
Russell's Avatar
If I remember correctly -- A1 has one of the best setups out there, and most guys who installed them were quite happy
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-28-2005, 02:36 PM   #3
barn9
Half a bubble off!
barn9's Avatar
What Russell said! If you get them, it would be nice to have a record of the install (with pics if possible) for the FAQ section.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 04-28-2005, 02:42 PM   #4
lngbed71
Nothing fits but the oil
lngbed71's Avatar
Stay tuned. I have the A-1 kit and will do an install starting next weekend. I ordered the square switches (you know old school GM looking) and plans are to fab up mounting insid the armrest pulls so I can retain the cranks in their position. I will post pics, and details. I am impressed with the tech article, parts and pieces.
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 04-28-2005, 03:05 PM   #5
Brewski*
Brewski*'s Avatar
I am thinking bout a kit also. I like the conversions I see in Classic Truck mag ads where the switch kit uses the factory cranks to control the switch. Any one seen these also. They look way cool.
Brewski* is offline   Reply With Quote
Old 04-28-2005, 03:48 PM   #6
GreyHoundSteve
got them, installed them, happy with them. The guys on the phone are friendly and helpful too and they gave me free shiping because i bought switches and door locks also.
GreyHoundSteve is offline   Reply With Quote
Old 04-28-2005, 04:40 PM   #7
71RestoRod
71RestoRod's Avatar
I just finished installing the A1 kit with Auto-Loc crank switches. It came together really nice, but was a little tricky to install because of the way I mounted the crank switches. I mounted the switches to the A1 regulator brackets and installed the regulators in the door. Getting the glass mounted on the regulator (with the regulator already mounted) was the tricky part. Now that it's all together... pretty cool. Looks totally stock. My passenger side window is just a little slow rolling up, but all the window seals are brand new. I think it will free itself up with some time. Otherwise, I may have to trim back the seal slightly.
There is a previous thread with pictures of the install (if search comes back up). I'll post a few pics when I get home if there is any interest.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 04-28-2005, 06:04 PM   #8
1970 CST Short Wide
Senior Moment
I would definatly like to see some pics
THANKS
Pittsburg Ca
94565
Old 04-28-2005, 07:15 PM   #9
Maxwell007
Just bought a kit.
I live close to A-1 and stopped by to look before I bought. Fortunately I mentioned that I had a one piece window in my truck and the guy told me that their kit would not work. I had to buy the "universal" hot-rod kit that uses the cable drive. I have the door all apart now and it appears that there will not be enough room for the regulator to clear the window. The instructions say that you need 1 inch clearance. Doesn't look like to me that I have that much. Anyway I am going to play with it a bit and see if I can get it to work. If not, I understand that Brother's Trucks has a regulator that works with the one piece window. It is a bit pricey though at over $400, but if that's what it takes........
I'll keep you posted.
Maxwell007 is offline   Reply With Quote
Old 04-28-2005, 10:04 PM   #10
71RestoRod
71RestoRod's Avatar
As promised...
This first set of pics shows the A1 regulator and the Auto-loc crank switch. I fabricated a couple of plates to mount the switches directly to the regulators. There is just enough room for the switch to fit in the right position without the regulator gear hitting it at full extension. There is also just enough space for the switch between the regulator and the vent window channel. Luckily, The spade connectors for the wiring ended up facing forward in the perfect orientation. I had to shim the switch on the regulator slightly to set the switch shaft perpendicular to the door; otherwise it wants to point down a little bit.
Old 04-28-2005, 10:05 PM   #11
71RestoRod
71RestoRod's Avatar
... and a few more
For the door loom, I used 5/8" rubber loom that I bought quite a while ago from a hot rod supply place (sorry, can't remember from whom now). I drilled oversized holes in the door and A-pillar and installed PCV grommets, then ran the loom through the grommets. I lined up the hole in the A-pillar with the existing hole that was inside the cab for the courtesy light wiring. I had to open up the existing holes under the dash to ~5/8" to fit grommets large enough for wiring both the power windows and power door locks. I actually drilled these from the outside in because I had already installed the AC box and parking brake). I also ran an extra set of wires to the regulator motor so that I might possibly wire switches in the center console in the future.
The trickiest part of the install was getting the side window and vent windows in. It's a little nerve racking with fresh paint. I taped up the exposed paint for protection and basically lucked out in the end. I first installed the regulator with the switch, finished the wiring (I used 4-wire weather pack connecters on the window wiring for ease of future removal/maintenance) and wired the power door locks. I then installed the window seals and jam side channel. I dropped in the window, front side first and caught the front roller. There was just enough wiggle room to get the rear roller in with the window shoved all the way forward. With the window rolled all the way down, I unbolted the jam side channel and slid the window all the way back to make room to install the vent window. Then I installed the vent window, shoved the side window forward and bolted back up the jamb side channel. I just took my time and kept thinking it was worth it... it really was much more of a pain than installing the windows with a stock regulator.
Old 04-29-2005, 09:53 AM   #12
GreyHoundSteve
I have the regular a1 regulators on my one piece windows and they work fine. Im not the only one on the board who has used them. You must have got some bad info, they work fine.
Old 04-29-2005, 01:01 PM   #13
1970 CST Short Wide
Senior Moment
Very Cool, Thanks for all the GREAT info. This needs to go into the FAQ section
I think I might just be puttin in an order real soon
Pittsburg Ca
94565
Old 04-29-2005, 05:15 PM   #14
lngbed71
lngbed71's Avatar
Very nice install indeed!! Is there a link, or part number for that switch?
Land of the free
Old 04-29-2005, 05:54 PM   #15
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
What happens when someone who doesn't know any better grabs your window roller and tries to roll down your window? Any chance of breakage?..........Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 04-29-2005, 09:58 PM   #16
71RestoRod
71RestoRod's Avatar
Thanks! This place had the lowest price I could find: Car Shop Performance Parts
The switch has a pretty stiff spring that lets you know what's happening. You move it a few degrees either way and the window rolls. It's also very strong... I don't think there's any way it could break.
I tried different positions for the crank handle and settled for straight up. It feels the most natural that way. I wired it so when you pull back it goes down; push forward it goes up... sort of lilke a toggle on a late model door switch. I also hate it when the crank handle bumps your knee... this way it's out of the way.
Old 04-30-2005, 11:57 AM   #17
dbzs
Work great
I've had a set installed about 5 years now and love them. Never did an install like this before, but I just took my time and everything came together. I didn't know about the crank switch, so I purchased some momentary rocker switches and mounted them in some chrome hole plugs I picked up at the hardware store. I wired them up and popped them in the crank holes, work great. I've got a suburban and couldn't find a kit for the rear windows, so I took a pair of the A-1 regulators and moded them. Took off the toothed plates that attache to the scissors and welded the factory ones to the A-1 scossors. windows roll up fine, but leave a couple of inches of glass exposed in the down position. Overall they work great, it looks like I updated the truck so the children can't climb out on the freeway.
dbzs is offline   Reply With Quote
Old 05-02-2005, 12:20 AM   #18
lngbed71
lngbed71's Avatar
Whew......well I found two switches, they are ordered. Do you think I can attach them to the door separately? That attach to the unit looks cool as he!! but maybe a bit complicated for me I think. Awesome post, I'm glad this board is here!!!!
Land of the free
Old 05-02-2005, 03:14 AM   #19
67chev
67chev's Avatar
I just did the install yesterday and today and love it! Their prices are awesome also. I have seen those same units go in magazines for $405!! When I saw their prices, I didn't even think twice...I ordered! Very easy install...just take your time.
"SicStee8" Chevy SWB Fleetside, in progress...500 HP 383 w/TriPower, 700r4, 3.73's, Lowered, Shaved Driprail/sidemarkers/handles/ant, Gonna rock!!
'96 Chevy Tahoe 4X4
'84 Chevy C/K10 4X4 (FOR SALE)
67chev is offline   Reply With Quote
Old 05-02-2005, 01:01 PM   #20
71RestoRod
71RestoRod's Avatar
You could try it... It will be tough, though, because you will have to install the regulator first. You will also need some sort of spacers between the inner door panel and the crank switch. Let us know if it works!
Old 05-02-2005, 01:07 PM   #21
Lobo'74
Lobo'74's Avatar
71RestoRod
What window seals did you use? I put new ones in and there is still a 1/8" gap between the glass and the seal in some places.
"Truck"
'67 small window
'79 350 .030 over, LT1 "clone"
Lobo'74 is offline   Reply With Quote
Old 05-02-2005, 04:52 PM   #22
71RestoRod
71RestoRod's Avatar
Lobo,
I got them from LMC. They have the chrome bead. It came as a four piece kit, L&R inner felts, L&R outer seals.
I don't know if the seal on the passenger side is just too tight or if the rubber is stiff... but the window screams up and down with the outer seal removed. With the seal installed, it drags noticeably when going up.
There is no gap on the seal... in fact it rides 1/8" to 1/4" on the side window glass.
Old 05-02-2005, 10:41 PM   #23
lngbed71
lngbed71's Avatar
Now I am so amped on this scheduled upgrade!!! I think maybe if I mount the switches behind the door where the hole for the crank was, I'll be okay. If not, I have great back-up via this thread!!!! Stay tuned, will keep you posted.
Land of the free
