Old 04-28-2005, 03:58 PM   #1
COBALT
COBALT's Avatar
I'm a dumb-ass.
Yep, it doesn't happen very often, and there's been a lot of people in my life that give me grief because they claim I NEVER admit it when I screw up, so here it is.
Sunday I had to run an errand for the wife in the truck. On the way back I saw her across the street and decided to get her attention by smacking the horn button a couple of times. Boy, did I. The horn stuck. BEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE..... It's blasting away, and I had to run around, pop the hood, and disconnect it before it made me deaf, and I had a gang of people after me with torches and pitch-forks.
Long story short I drove home, parked the truck, and decided to fix it later.
This morning I went out to drive my truck to work. Dead battery. It took me a couple of seconds to realize what an idiot I am.
...so I have to take the steering column apart AGAIN to figure out why my horn is sticking. Anyone have any problems with their horns? That spring loaded pin on the turn signal canceling cam and that round thin metal plate that connects to it I think are the culprits. Something is shorting it out and making the horn go off.
Any ideas?
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 04-28-2005, 04:04 PM   #2
70GMC_BOB
I have had the thrun spring break on 3 diff trucks. the last was on my 72 w/ a dual airhorn decide to go off at 2am monday morning. I had a whole apartment building pissed off, but it was so loud all I heard was a couple who said was thankyou. but then again I wasn't hearing much of anything at that point!
1972 chev c20 2wd lwb 350v8/th350. (dad's)1970 gmc longstep (9ft commercial bed), 1 ton, 2wd, 350/th400.
70GMC_BOB is offline   Reply With Quote
Old 04-28-2005, 04:13 PM   #3
70c10
67-72 Addict!
70c10's Avatar
I recently replaced the turn signal lever when I put in a new switch in my dad's truck. Now his horn goes off on left turns, lol. The screw that holds the turn signal lever arm on, is making contact with the back of the steering wheel. I am going to grind a tad off the face of the screw to make it shallower and I know it will be fixed. This is my plan anyway. Good luck Cobalt.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-28-2005, 08:12 PM   #4
JimKshortstep4x4
Talking
It sounds like the metal diaphragm is caught on the mounting tabs of the insulator which will keep it in contact with the steering wheel.
Jim
Old 04-28-2005, 08:15 PM   #5
silvertonguedevil
silvertonguedevil's Avatar
These things came with horns??
(Mine has never worked!)
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 04-28-2005, 08:35 PM   #6
BurnoutNova
BurnoutNova's Avatar
i had the same probleom in my 76 nova, the P.O. had installed an aftermarket steering wheel with a cheap adapter and the horn wire got pinched inbetween the wheel and adapter plate. i drove it for a few blocks before pulling over. it made it even worse it had air horns on it... it was a little embarassing.
BurnoutNova is offline   Reply With Quote
Old 04-28-2005, 11:05 PM   #7
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
I had a truck that the horn would go off when I put the clutch in. That was actually funny once in a while.
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 04-28-2005, 11:29 PM   #8
moneyguru
moneyguru's Avatar
Well, old ex girlfriend, actually she became my ex wife, had a plymouth volare.
Biggest P.O.S!!!
Well anyway, plymouth put the highest grade foam in the steering wheel for the horn.
Along came winter and the foam contracted and the horn would start screaming! I pondered for days how was I going to fix this (cheaply), and then I was opening up some boxes (worked on a receiving dock then) and unwrapped this lovely foam from around a smaller box.
Couple cuts with a knive and in it went, never to go off by itself again.
Now back to GMC topic, I heard a rumor these trucks could have a horn as an option...what do I need to do to install one in my 67? LOL
"Do the things you fear to do and the death of fear is certain"
moneyguru is offline   Reply With Quote
Old 04-28-2005, 11:39 PM   #9
useRc10
useRc10's Avatar
mine does it...the turnsignal shorts out and makes the horn go off...fun when theres a cop behind you and you either have to blast the horn or not signal a lane change
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 04-29-2005, 07:59 AM   #10
So what happened once you got her attention?
Old 04-29-2005, 08:25 AM   #11
67ChevyRedneck
67ChevyRedneck's Avatar
I had the same problem. Real simple fix. It's been unhooked for about 6 years. Get a dixie horn. When someone cuts you off and you blow the horn at them you can't stay mad when dixie comes out! Da da duh duh da da da da duh duh da da.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-29-2005, 11:37 AM   #12
Alexis
Member since 2000
Alexis's Avatar
Alexis is offline   Reply With Quote
Old 05-01-2005, 06:21 PM   #13
COBALT
COBALT's Avatar
She covered her face and pretended not to know me. She told me later that some guy standing on the corner with her said something like "man. it sounds like his horn is stuck. Do you know him?"
She reluctantly said, "Yes, he's my husband."
found the problem. It's this stupid turn signal switch/wiring harness in the column. The wires that go into the switch (all 8000 of them) keep getting pinched when I try to route them around inside the turn signal housing to keep them away from the screws. The first time around the white one got pinched (part of the circuit that controls the panel lights, the dome light, and the tail lights???). It kept blowing fuses. This one was the black one that goes to the spring loaded pin on the turn signal switch for the horn.
First, I had to go get a new battery. I tried to jump it but it wouldn't take a charge long enough to get the truck running. When I pulled it to take it to an auto parts store to get it charged I found out it was leaking. I went and got a gel core sealed battery that cost me about $130 but I'm tired of these cheap-ass batteries that rot out my battery tray.
Second, I disconnected the horn and used my 12v probe tester (with the bulb in the handle) to bypass the horn. Then I could see when the circuit was live rather than hear it till I was deaf.
Third I took the column apart until the light went out. When I went to remove one of those 3 big phillips head screws that hold the switch inside the housing the light suddenly went out. There it was....pinched black wire with copper sticking out and touching the screw.
so...after patching that and CRAMMING the wires back in hoping they weren't being pinched again I was good to go. The new battery rocks.
I think I'm going to get a different turn signal switch. This one I got from LMC is garbage.
Seattle, WA.
Old 05-01-2005, 07:02 PM   #14
69 longhorn
Its good to hear that you found the troubles.Oh.....welcome tothe dumb@ss club.....I think I founded that say 25-30 yrs ago! LOL! I dont think there is a one of us that hasnt been caught with some kind of chit from these 30+ yr old trucks.......unless there is a d@mn good liar or 2 out there Hang tough.... L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 05-01-2005, 08:10 PM   #15
Fred T
Cantankerous Geezer
Fred T's Avatar
There are two different grades of turn signal switches out there. If it happens again, unplug the horn relay, it's next to the fuse box. That way your battery won't get drained. On the vendors, there are many that are better than LMC. I deal with Bowtie Bits and GMC Pauls.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 05-01-2005, 08:13 PM   #16
86SILVERADO
86SILVERADO's Avatar
Originally Posted by Alexis
HAHA, even my yankee butt knows what he is talking about. Never seen Dukes of Hazard?
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
Old 05-01-2005, 08:32 PM   #17
Alexis
Member since 2000
Alexis's Avatar
Hell Yes I've seen it, use to watch it when I was a kid. They now play it on CMT but I don't watch much TV.
I know what a dixie horn sounds like but I couldn't match up his "da da da buh da da" to it
Old 05-01-2005, 11:42 PM   #18
72moneypit
72moneypit's Avatar
I did the VERY SAME THING about a year ago. About 2 hours after I replaced my turn signal switch (with a cheapy aftermarket one), the horn starts blaring in the driveway. I run out and pull the wires off the horn, tinker with it awhile, and eventually give up for the day. The next morning... dead battery! I had to haul the battery to AutoZone for a recharge. Doh!
Ultimately, I bought a "genuine GM" turn signal switch from someone here on the board. It was clearly superior in quality to the cheapo I'd originally installed. It's worked problem-free since.
Paul
72 Cheyenne Super Custom Camper
greenaz@hotmail.com
72moneypit is offline   Reply With Quote
