Old 04-29-2005, 05:53 AM   #1
72longbed
72longbed's Avatar
Question New Spindle Install??
I put a pair of 'factory new' Spicer spindles on my Dana 44 front axle last night and was wondering if maybe they are not the right ones for the knuckles? I had to use the 'persuasion method' with a brass hammer to remove the old spindles, everything was rusted really bad. I then had the knuckles sand blasted and painted with Rustoleum black. I bought the new spindles over the internet and checked all of the critical bearing areas with a micrometer.
These new spindles bolted right into the knuckle without any forcing. I thought they were supposed to be a really tight 'press fit' into the knuckle??
Has anybody replaced their spindles with new, non-rusted ones and experienced the same thing? I know the entire wheel assembly rides on that little spindle and want to make sure that I have installed the correct part safely.
Thanks for your input,
72longbed
72longbed is offline   Reply With Quote
Old 04-29-2005, 09:23 PM   #2
kwmech
They should slide right in, myself I put anti-seize on the inside of the hole so removal later is easy.
Old 04-30-2005, 12:37 AM   #3
72longbed
72longbed's Avatar
Thumbs up
Thanks KW,
thats good to know. Last thing I want to do is snap a wheel off at 60 MPH.
Thanks again,
72longbed
