Old 04-29-2005, 08:20 AM   #1
Nolowrider
Nolowrider's Avatar
Burb seats in my stepper
Hello, Can anyone tell me if the bucket seats out of a 83 burb would bolt directly in my 74 steppie (or maybe alittle modification). I found a good looking burb with a of nice accessories yesterday. Guy wants $40.00 a piece for the seats. Lots of nice trim, ect. I hope they fit, I have been looking for a good set of seats for about 6 months now. Thanks guys.
Nolowrider is offline   Reply With Quote
Old 04-29-2005, 09:00 AM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I have never tried it, but you should have to do some bracket fabrication. The floor in the pickup is different from the Suburban and Blazer.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-29-2005, 09:05 AM   #3
beaterC10
I put a set of Blazer seats in my stepper with a collection of factory parts. The Blazer and Burb seats are similar in construction on the underside.
I shortened a set of p/u bench seat sliders since they fit the pickup floor and attached them to the Blazer seats with Burb attaching brackets. I used a set of Burb brackets for the front inside floor attachment location. These were cut out of a Burb with a little extra material all the way around. A little trimming and hammer work was required to get them to fit on the p/u floor, but it was very minor.
I offset the outside seat slide attachment on the bucket to get the bucket centered on the steering wheel using the factory attachment points in the cab. Once that was good, I bolted the Burb floor attachment bracket to the inside slider and used sheet metal screws to get it located on the floor of the cab.
The whole project took about a week of evenings to accomplish using nothing more advanced than a hacksaw, drill, and grinder. I went this route since I got the seats for free and bought the Burb parts cheap.
beaterC10 is offline   Reply With Quote
Old 04-29-2005, 09:22 AM   #4
Nolowrider
Nolowrider's Avatar
Thanks for the info. I was hoping that they were a direct bolt in, but if I have to do some minor fabricating that's ok too. I have all all the hand tools that I need, but no welder. I knew it was too good to be true.
Old 04-29-2005, 09:26 AM   #5
beaterC10
Don't let the fabrication scare you off, it was minor. More thinking involved than working. I had a neighbor weld the brackets in after I located them with screws. You could drive the truck to the welder after the seats are in.
Old 04-29-2005, 09:39 AM   #6
Nolowrider
Nolowrider's Avatar
I think I can handle the fab work. My best friend owns a fab shop, so he can do the welding for me. But, no fab is always better. Thanks for the advice.
Old 05-07-2005, 04:40 PM   #7
zieg72
I have one in my 85. Fits fine although I am a little closer to the steering wheel than I would like. The seat also won't allow you to access the back of it. I have a seat cover on order and will retain my 85 seat after it is recovered.
zieg72 is offline   Reply With Quote
