Old 04-29-2005, 08:21 AM   #1
67chevemall
67chevemall's Avatar
Question The GAS won't stop AHHHHHHHHH!!!!
I put a rebuilt holley 4150 on a week ago and can't get the fuel to stop
pouring out of the sec. bowls? I have the check plug out trying to
adj. the bowls but nothing will stop it. I took the bowl off to see if I left
something out but it all looks good. What could this be?
It will run with fuel pouring out the sec. check plug at a fast rate
but the truck burps and farts bammmmmm bammmm. I'll end up blowing the
truck up if I keep this up.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 04-29-2005, 12:14 PM   #2
'70_402
'70_402's Avatar
I Had This Same Problem And I Sent The Carb Back To Holley And They Sent Me A New One..
'70_402 is offline   Reply With Quote
Old 04-29-2005, 12:21 PM   #3
67chevemall
This is a early 70's carb that I really want to work. Everything looks good I
can't see why the gas won't stop.
I temped to get a fitting and disconnect the secondary and try it.
Old 04-29-2005, 12:32 PM   #4
jhow66
jhow66's Avatar
You have got a piece of dirt of lint (or something of the like) between your needle tip and needle seat. It only takes a very ,very small speck. Screw your needle all the way out and wash out and blow dry with air hose.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-29-2005, 01:38 PM   #5
71cadc10
71cadc10's Avatar
also might want to try and set your float level with the secondary bowl on the bench, before you put it on the carb. That should get you fairly close. I know with center hung, you set it with the bowl upside down, and center the float. With Side Hung, I'm not 100% sure but the Holley website has the info I'm sure.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 04-29-2005, 04:11 PM   #6
67chevemall
Set it on the bench? Maybe my bowl isn't striaght.
I'll take it back off and check. Also I'll search the holley site.
Old 04-30-2005, 12:25 AM   #7
muddbugg72
take your needle seat out and clean it out. with your bowl off and upside down there should be about 1/2 in. gap between top of bowl and float. you can use a 1/2 in. drill bit to get the clearance. hope that helps.
muddbugg72 is offline   Reply With Quote
Old 05-02-2005, 07:40 AM   #8
67chevemall
muddbugg thanks for the tip it worked my bowl was bent down to far.
Now it runs with no leaks but is back fireing like crazy.
I thought it was the acc pump so I backed it off all the way disconnecting it.
But it still back fires I tlooks to be wet in the primarys????
Old 05-02-2005, 09:46 AM   #9
RON WOODGEARD
Resident Young Old Dude !
I told you this over a week ago...
RON WOODGEARD is offline   Reply With Quote
Old 05-02-2005, 10:47 AM   #10
Hotrodhenryj
Truck Farmer
Hotrodhenryj's Avatar
The backfiring is caused by a blown power valve. This is a common Holley problem. They make one now to replace it, you can buy it at Napa. Good luck
Arizona rust free sheetmetal
Hotrodhenryj is offline   Reply With Quote
Old 05-02-2005, 03:45 PM   #11
67chevemall
So 1 or 2 backfires and your powervalve is blown. Cause it must have done that
20 times bing ping bam!
Now that my floats are good I should be able to replace the power valves and be on
my way. I hope.
? How do you know they are blown is there a test? Or should I replace both of them.
Old 05-02-2005, 05:09 PM   #12
cduster
If it were me, I'd replace both of them. Holleys are bad for the power valves blowing when it backfires. One little pop is enough to bast one of them.
Dan
Good Judgment comes from experience.
Most experience comes from bad judgment.
cduster is offline   Reply With Quote
Old 05-02-2005, 05:33 PM   #13
cableguy0
do yourself a favor and by the power valve blowout protection kits summit and jegs both have them they are a little check ball that you install that stops the power valve from getting blown out
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 05-02-2005, 06:10 PM   #14
Hotrodhenryj
Truck Farmer
Yea, what they said!
Old 05-02-2005, 11:18 PM   #15
67chevemall
I will get them 4 sure.. I want to .. bla bla
Never mind.
I am tring a 78 Q jet right now but the fn fuel line filter white donut gasket on the
main line is done.
Search for one tomorrow.
2 learn more I should be able to run both 20 minutes apart.
8
Old 05-03-2005, 12:37 AM   #16
RON WOODGEARD
Never mind.
main line is done.
8
I'm not sure what 20 minutes apart mean, But there is some very Informative Holley books on the Market, And if you are going to play with them Buy all you can afford, Yes, You will get some of the same stuff from each one, But most of these tech. writers have little tid bits Inclusive to their manual,(Book).
