Old 04-29-2005, 11:35 AM   #1
81shortwide
Removing a leaf ??
Is there anyone who has removed a leaf from their spring pack? I have an 81 Silverado SWB, the thought is that I could drop the truck a little and also make the ride a little softer. I know how to take the truck apart, but was wondering how the leafs actually seperate from each other? Also curious as to how the locating pin would be effected. Would it need cut down so it doesn't contact the axle tube after it goes through the perch?
Probably self explanatory once it's apart, but I don't want to get 1/2 way into it and find out it wasn't a good idea. Thanks
66' chevyII-406,glide,9" (12.11@113)
81' chevy shortwide
hoping to add a "burb" to the list
81shortwide is offline   Reply With Quote
Old 04-29-2005, 11:27 PM   #2
Truckstuff
Truckstuff's Avatar
The springs are compressed together, and held by the center pin. Clamp the spring with two large C-Clamps, one on each side of the center pin. Undo the bolt on the pin or cut it. (I wouldn't reuse the pin, get a new one) Then slowly back off the clamps and they will separate. This is also a good time to replace the cushion pads if needed. The pin can be cut after you put the spring back together.
Real Trucks are Built not Bought
Building: 1981 GM SB LowRider
1985 GM K3500 3+3
1981 GM K2500 SSB
1980 GM K2500 X-BC Hydro
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Truckstuff is offline   Reply With Quote
Old 04-30-2005, 09:59 PM   #3
72MARIO
72MARIO's Avatar
You may need shorter U-bolts also
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-05-2005, 09:36 AM   #4
keb
keb's Avatar
I would like to do this with my 57 Chevy ... how will this affect the steering linkage ... if it will at all?
keb is offline   Reply With Quote
