Old 06-12-2002, 08:31 AM   #1
tim m
Rear axle
The rear axle housing is leaking gear oil, it is where the tube is pressed into the housing. Can I just weld a bead around it to seal it, or is there some other way to fix this?
1970 k10
1971 C10
Gilbert Az
tim m is offline   Reply With Quote
Old 06-12-2002, 08:53 AM   #2
Mike C
Mike C's Avatar
Are you sure it is leaking from the tube? Sometimes it can be coming from a gasket or front seal and migrates. Also check the vent tube on top to make sure it's not puking due to overfill. You can weld the tube to the housing, and a lot of faster vehicles do so to keep from rotating the tube in the housing (!) but be careful. Localized heating can warp the housing so keep welds short and rotate the housing. ie weld an inch, and rotate the housiing 120 degrees, weld another inch, rotate another 120 degrees, weld another inch. Let the whole thing cool, then start next to your first weld.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-13-2002, 02:30 AM   #3
Fast68Chevy
Fast68Chevy's Avatar
and keep in mind that the diff housing is iron and the tubes are steel so welding wil be little different, i have come across some 12 bolt axles with welded tubes that soemone has welded all the way around on. i havew one such axle here soemwhere stashed away but am tossing soon for scrappers to haul away, its a 69 one.
Fast68Chevy is offline   Reply With Quote
Old 06-13-2002, 08:09 AM   #4
tim m
Is there any other way to fix it then. That was the only way I could think of to fix it.
1970 k10
1971 C10
Gilbert Az
Old 06-13-2002, 04:05 PM   #5
Mike C
Mike C's Avatar
Steam clean it/pressure wash it/degrease it then put new pinion seal and cover gasket on and eyeball it for a few days to pinpoint the source of the leak and then proceed from there. As noted before, the tubes can be carefully welded, but be sure that's the source of your leak first. Also check the vent to make sure it's not clogged up.
