Old 04-29-2005, 05:41 PM   #1
ecameron87
Repair bolt nuts in fiberglass?
Now that I have the top off, I would like to start fixing it up. The biggest problem I have right now is that I cannot bolt down at the passenger side visor bolt. The nut is spinning freely inside the top. I also have a bolt rusted to the nut at the center passenger side tie down going into the windshield frame. That bolt/nut spins freely as well. What would you guys do to fix this problem?
ecameron87 is offline   Reply With Quote
Old 04-29-2005, 05:50 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Tough problem. Could you cut out the nut embedded in the fiberglass and embed a new one?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-29-2005, 06:14 PM   #3
72CSTC5
72CSTC5's Avatar
I haven't looked at my top in quite a while but what if you chamfered around the edge of the nutsert and then you could use some adhesive to glue it back to the top securely. Don't know if that would work if the top is solid around the insert or not. Just a suggestion.
72CSTC5 is offline   Reply With Quote
Old 04-29-2005, 08:09 PM   #4
HatGuy
HatGuy's Avatar
I've got the same problem on the driver side.
Joe Peters the HatGuy
72' K5 Highlander
My Daily Driver
http://www.pbhats.com/BLAZER/index.html
HatGuy is offline   Reply With Quote
Old 04-29-2005, 08:17 PM   #5
71jimmy
71jimmy's Avatar
I believe the nuts are actually on a piece of metal that runs inside the fiberglass. Nuts in just Fiberglass alone would not hold. I cut a double wall up awhile back (I know not good, but it was trashed) and along the side rails that is how it is. At the windshield, the nuts are on 2x2 pieces of metal. Just my .02.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 04-29-2005, 08:19 PM   #6
71jimmy
71jimmy's Avatar
Oh, to repair your going to have to make some cuts to remove the entire strip of metal on the side rails or the piece/s for the windshield. Chances are the metal along with the nuts are going to be rusted and need replacing anyway.
Old 04-30-2005, 02:43 PM   #7
ecameron87
Now that I look closer, the nut is welded to a piece of metal in there. I guess I will have to do some surgery on it this summer, or just go soft top next winter if I can get up enough money.
Thanks for the help.
