Old 04-29-2005, 10:00 PM   #1
bigred66
bigred66's Avatar
Drop blocks
Maybe stupid questions were could I find drop blocks for my 66? I keep finding s-10 ones are these are small right or can I use them?
Atom (bigRed66)
1966- C10
1995- Wide Body Talon
1987- Dodge Raider (4 sale)
2000- 4-door Nissan Frontier
2003- Ford Focus (wife)
bigred66 is offline   Reply With Quote
Old 04-29-2005, 11:16 PM   #2
kamikazegmc
Registered Smarta$$
kamikazegmc's Avatar
any auto parts store should have some universal blocks for leafs, but your most likey looking for block trailing arms.
63 GMC custom
going to be slammed
kamikazegmc is offline   Reply With Quote
Old 04-29-2005, 11:20 PM   #3
bigred66
bigred66's Avatar
i must need more help than i thought
Atom (bigRed66)
1966- C10
Old 04-29-2005, 11:41 PM   #4
kamikazegmc
Registered Smarta$$
i ment blocks for trailing arms.
63 GMC custom
going to be slammed
Old 04-30-2005, 02:30 AM   #5
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
Block for trailing arms are different because the U-Bolt goes throught them. Check out cpp(classic performance parts) they have a 2 inch kit.
Bagd72Chevy is offline   Reply With Quote
Old 04-30-2005, 08:49 AM   #6
72BLAZERDUDE
72BLAZERDUDE's Avatar
CPP is where we got ours. And also 2" is as tall as you want to go.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 04-30-2005, 09:47 AM   #7
bigred66
bigred66's Avatar
Thanks they are on the way now
Atom (bigRed66)
1966- C10
Old 04-30-2005, 10:10 AM   #8
jlaird
jlaird's Avatar
thanks 72blazerdude. I was just about to ask that question! While I'm writing...what would be the adverse effects of a 3" block?
jlaird is offline   Reply With Quote
Old 04-30-2005, 10:32 AM   #9
Bagd72Chevy
C10 Collector
One problem is the bigger the block the more your axle is pushed forward when you let the air out. Not much, but you can see it.
Old 04-30-2005, 11:00 AM   #10
jlaird
jlaird's Avatar
Ok, that's good info to know. So when I go to find center on my frame for the c-notch, I will want the blocks in first, right? (just learning, don't make fun!!)
josh
Old 04-30-2005, 03:03 PM   #11
72BLAZERDUDE
Using 3 inch blocks starts putting things like shock mounts way to close to the ground. If you used 3 inch blocks with a shock relocating kit like ECE it will put the lower shock mount somewhere close to 2 inches from the ground. Granted it is in the centerline of the rear wheels but thats to close for me.
Old 04-30-2005, 03:22 PM   #12
kamikazegmc
Registered Smarta$$
i was thinking of getting some drop blocks (the ones for leafs), but i have two questions if i go w/ 3" block wouyld i need new shocks? and right now my leaf are above the alxe what do i need for the block to work/ how do the block work?
63 GMC custom
going to be slammed
Old 04-30-2005, 04:49 PM   #13
1FaastC10
1FaastC10's Avatar
you need a flip kit first, which will give you 5-6" depending on your springs, your rear axle, and the flip kit manufacturer. you can get shackles to give you 2", shackles and hangers to give you 4". drop springs are another option
1FaastC10 is offline   Reply With Quote
Old 05-01-2005, 12:28 PM   #14
Peregrine
Peregrine's Avatar
I will tell you this. I recently discovered that if you want to run your exhaust out the rear by going over the axle tubes you can do it if you have 2 inch blocks and 3 inch springs.
Brian
72 C10 longbed 350/th400
Let the world change you and you will change the world.
Peregrine is offline   Reply With Quote
Old 05-01-2005, 03:13 PM   #15
SCOTI
SCOTI's Avatar
josh
You should measure the axle C/L w/the rear end bottomed against the frame w/the blocks installed.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-02-2005, 02:27 PM   #16
fastbagged68
fastbagged68's Avatar
I got 3 inch blocks and mine are not close to the ground... It depends on how tall your tire is. I got 29.5" If you are running a 25"-27" tire it would effect it though!
fastbagged68 is offline   Reply With Quote
Old 05-02-2005, 02:42 PM   #17
smokekiki
Mike
smokekiki's Avatar
Also with a big block,if You get a flat,You will be skidding on the ubolts and trailing arms,instead of the rim and tire.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 05-03-2005, 09:02 AM   #18
jlaird
jlaird's Avatar
is cpp the only place to get them specifically designed for our trucks?
Old 05-03-2005, 07:07 PM   #19
bigred66
bigred66's Avatar
nope http://www.gmcpauls.com/67-72_d&s.htm and http://www.performancesuspension.com/TruckLowerTwo.htm are the 2 others i found
and i think these http://www.stockcarproducts.com/trkarm1.htm would work
Atom (bigRed66)
1966- C10
Old 05-04-2005, 02:08 AM   #20
Rollie396
someday it will be done!
Rollie396's Avatar
just a quick note.If you are running your bags in the original spring location,you will need more than a c-notch to clear.I fabbed a 2.5" notch,installed the bags and tested it to find that there is about a 1/2" of room left in the notch when aired out.This is with no drop blocks.Make sure to post some pics of your install!
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 05-05-2005, 09:05 AM   #21
jlaird
jlaird's Avatar
Is what rollie396 true? Does it depend on what size wheels/tires your running?
I thought a bolt-in c-notch, 2-inch blocks, and bag in stock coil location was a fairly common set-up.
Josh
Old 05-05-2005, 11:54 AM   #22
fastbagged68
Yes Rollie396 is correct.. Tire size doesn't matter on what he is talking about. The bag is bottom out between the trailing arm and the frame.
