3sp column shift backup light switch replacement
I just thought I would share in case this might help the next guy doing
this job. To be honest, it was a real pain. I got a new switch in the mail and took a look at it and it seems simple enough. The unit bolts on with two small bolts right onto the column under the dash near the firewall. Taking the old one off was easy and I saw that the little black plastic lever had broken off. The whole switch was blackened so I wanted to replace it instead of fixing it. The new one looked identicle, but did not fit perfectly. These switches mount to a metal bracket that is easily bent and therefore it can really tweak itself into the wrong position. I installed the switch 25 times! Every time it did not quite work right. Sometimes the light would not come on in reverse. Sometimes it would come on and not go out when taken out of gear. But if you wiggled it it would turn off. Finally I took a dremmel tool and widened the two bolt holes on the mounting bracket so I could adjust its placement more and got it to work correctly. For some reason the switch needed to more more to the right than the original bracket would allow. Once I could slide it over another 1/8th of an inch it worked perfectly. A 10 minute job turned into a 5 hour pain, so I thought it deserved a rant ![]()
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree Last edited by farside847; 04-29-2005 at 10:06 PM. |
Where's my beer?
Don't you hate stuff like that? And now if you had to do it over again, it would only take you that 10 minutes even having to enlarget the mounting holes.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
I have a question about the installation of the new switch (I too have struggled with the installation).
When you installed the switch, did you insert the little metal rod (from the steering column) "into" the little black square sliding switch, or "beside" the little black square? I guess the little metal rod is what moves the sliding switch, when shifting into reverse. Did you position it "into" or "beside" the sliding mechanism?
KDD |
