Is this a posi?
I know absolutely nothing about gears or posi so was hoping one of you guys would be able to tell me something from this picture
Thanks in advance ![]() |
![]() ![]() Join Date: Jan 2005
It looks like a posi to me. I think I see a spring in there.
Looks like the one I have outside
Martin Gibson
USAF Retired 1964(-ish) C10 |
Seasonal Poster
Yeah, I think those springs have something to do with the posi clutches in there.
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
Posi...or not???
Yes that is definately a limited-slip/posi carrier. However, does it work??
If it's still on the vehicle, put trans in neutral, block front wheels, disengage parking brake, jack one rear tire off the ground and see if you can spin the tire that is in the air. If tire spins, posi unit needs work. if tire dosen't want to move, looks like your posi-unit works!! Good luck, rwgregory
rwgregory 67 GMC 2500 ,2w/d wide box 305 V-6, 4-speed |
#6 | |
#7 | |
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
I jacked up one wheel and it wouldn't spin in nuetral so i 'm guessing that means everything is cool right?
![]() Join Date: Nov 2003
Well, you probably can't apply as much torque to the wheel as your engine can. Unless you transplanted a Honda into there. But, if it did spin you would have known for sure that it was toast.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
i did the by hand slip test on my rear end before i put it in the truck, and we had a long jack handle throught the wheelstuds trying to turn it, it felt really tight... but a few times in the snow it slipped.
just go do a burnout and se how many marks it leaves |
Hey burnout you tryin to get the police to my house? lol
#12 | |
Got Light Emitting Diode?
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
