Old 04-11-2002, 09:50 PM   #1
RipMeyer
RipMeyer's Avatar
Post Wipers Are Kinda Slow. Can I Lube The Motor?
Was wondering if I can lube the wiper motor or something to make them move a bit eaiser?
Any suggestions?
Eric
RipMeyer is offline   Reply With Quote
Old 04-12-2002, 12:53 AM   #2
frost89434
frost89434's Avatar
Post
I had the same problem on my 68, I ended up replacing the wiper motor.
67 3/4 ton progect
68 chevy swb stepside
Sparks NV
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 04-12-2002, 04:01 AM   #3
Mudder
Mudder's Avatar
Post
lub the pivots the best u can with some wd or some spay lub
67 stepside 4x4 Owensville MO mudder67@hotmail.com
Mudder is offline   Reply With Quote
Old 04-12-2002, 05:56 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Arrow
Odds are the motor is going. You should lube all the pivot points anyway so give that a try first.
63 Impala*66 Chevelle SS*69 Chevelle*69 C10 Stepside*71 Cheyenne 20*72 Chevelle
Parts for sale:
http://www.angelfire.com/trek/mr409/items4sale.html
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 04-12-2002, 09:29 AM   #5
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Post
Mine was really slow. I found the previous moron had put foil on the fuse and reinstalled it. I replaced it with the correct fuse and it seems to run a little faster. Still slower than newer truck though. You might want to just put a new fuse in and see if that helps.
For the oil on pivots, I would suggest something thicker than wd40, although wd40 is better than not oiling it at all.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
