Old 04-30-2005, 07:19 PM   #1
pritch
pritch's Avatar
Found the problem with my gas gauge
All the wires seemed OK. As near as I could tell, the ohms were about where they should have been-I figured I had about a half a tank, and the ohms were about 45, so I pulled out the cluster to check out things there and to replace a couple lights that were not working and I found this:
See the break in the circut? (that also explained the lights not working) I had an extra circut board so I swapped it out and plugged in the wire harness and nothing! No change at all in where the gauge was (about 3/4 tank). I decided to change the gauge itself, so I dusted the donor up and changed it out and it worked! I studied the old gauge carefully and noticed that the needle was very stiff-much harder to move than the donor. I think it was stuck in place for so long that it kinda froze in place and wouldn't move.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 04-30-2005, 07:21 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-30-2005, 09:27 PM   #3
JimKshortstep4x4
Talking
Good job!
Jim
Old 05-01-2005, 01:38 AM   #4
shifty
Questionable
shifty's Avatar
I need to pop mine off and look at the circuit sheet for mine. I've got some weird stuff happening with some of the lights in my panel.
Glad to hear this thing is working! Every time I see someone have success like this, it makes me want to dig into my truck more and more
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 05-01-2005, 05:18 AM   #5
gabet40
heres one, my gauge only goes to 1/4 tank when full, but goes down porportionally after that. anyone else had that prob or might have an idea what it is?
Current owner of 2016 2500 Silverado Midnight Edition.
Former owner of:
69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4
72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust
gabet40 is offline   Reply With Quote
Old 05-01-2005, 11:34 AM   #6
70c10
67-72 Addict!
70c10's Avatar
gabet40- you might have a pin hole in your float. Pull the sender out and see if gas is sloshing around in the float.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-02-2005, 06:33 PM   #7
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
goes below "E"?
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
