Van Tilts
stupid question, what are van tilts worth?
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat) |
The LuvShack Garage
Last One I Saw On Here Was $175 (i Think)
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
![]() ![]() Join Date: Jan 2005
In my opinion it depends a lot on whether the shifter lever pin hole is worn or not. I'd say that if the pin hole is worn, it is worthless, unless you plan on using it with a floor shifter, and have the ability to remove the shifter lever attachment.
What year of van are you talking about? I have one out of a low mileage 83 Chevy Van with tilt and cruise, but wasn't sure if it fit our trucks or not.
Squid
'69 C10 LWB- 305, Holley 2 barrel, 700R4, 4/5 drop, dark blue primer!, cheap driver project... Back on the road... In time to sell on Ebay. ![]() |
I have seen them go for $100 quite commonly. More if they are modified and ready to go into our trucks.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#6 | |
The LuvShack Garage
its all about the +6 inches
The 83 column is too new to be an easy swap.
The columns to look for are the 72 - 81 and a hand full of early 82 vans too....basicly, any one with the key in the dash instead of the column. |
the ones i've seen are without the key in the column. are they easy to rebuild? if you rebuilt them, how much do the rebuild kits cost? thanks.
You can get $100+ into them if you purchase the three new bearings, rubber seals (firewall and bezel), and the turn signal switch.
