04-30-2005, 08:04 PM | #1 |
lowering the back by heating
Got some 3 inch drop spindles for the front. but realy dint want to spend the money for the flipkit on the back of my 81. Thought about heating the top of leaf spring a little. up by the rear shackle. im not going to haul nothing heavy. maybe later on put some air shocks. anybody ever do this, if so what was the out come or do you a cheper way out
04-30-2005, 08:13 PM | #2 |
*Proud Member*
i think it would be easier to just remove some of the leaves...
04-30-2005, 08:16 PM | #3 |
no its a easer to heat
04-30-2005, 08:24 PM | #4 |
*Proud Member*
good luck.
04-30-2005, 09:04 PM | #5 |
Certified Truck Nut
you dont have to buy a flip kit, you can do it yourself, thats how im gonna do mine. im just gonna by new perches and u bolts, and do it myself. you just wanna make sure and get the perches lined up with the old ones, and keep the pinion angle reasonable. i actually use the ubolts to hold it all together while i weld it up.
later Dan
1982 GMC Sierra Classic 1500 Longbed 350, TH350, 3.73 10 bolt soon to be slammed |
04-30-2005, 09:12 PM | #6 |
Until Seventy Times Seven
I've only seen pics of someone who heated the rear portion of the leaf spring to accomplish a lower drop. The deformed spring did lower the truck, but it was very compromised. Safety factors aside, the springs were ruined. For under $100, you should be able to do a flip kit to match your front drop.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... Last edited by boxrodz; 05-01-2005 at 01:45 AM. |
05-01-2005, 12:47 AM | #7 |
Insert Witty Text Here
I saw a truck done that way locally. The ride appeared to be quite choppy and bouncy. What is a flip kit from Summit, $90? I'd say it is worth it.
Slonaker |
05-01-2005, 03:55 AM | #8 |
there's no nice way to put this.
stop being cheap before you kill someone. heating a spring is not only dangerous to yourself, but whoever happens to be with you, or anywhere near you when it fails. no question that it will fail. Last edited by 1FaastC10; 05-01-2005 at 03:56 AM. |
05-01-2005, 10:25 AM | #9 | |
*Proud Member*
05-01-2005, 10:40 AM | #10 |
Thanks for the input everbody. Yall have talked me out of it.Its not that Im cheap. Its hard to to give 90 dollars for what looks like some 30 dollar brackets. Im going to build my own brackets. I found some thick channel in the garage last nite. Ill let yall know how it turns out.
05-01-2005, 11:11 AM | #11 |
Just remember that when you move the axle up that high, you will have to move it back a little on the leaf springs to compensate, or shorten the driveshaft. I agree that the parts you get do not look like they are worth the $90. If I knew that I could buy spring perches I would have.
When I did mine, I used the DJM kit and the axle was WAY to close to the bump stops. So I put air shocks on it, which raised it about an inch, and the ride quality is ten times better. Last edited by jermasaurus; 05-01-2005 at 11:12 AM. Reason: Font Problem |
05-01-2005, 02:29 PM | #12 |
c notch would've been the way to go, or shorter bumpstops. ditch the air shocks, and i bet the ride improves 10 fold again.
05-01-2005, 03:16 PM | #13 | |
05-01-2005, 06:49 PM | #14 | ||
Good luck in your fabbing. Quote:
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
05-02-2005, 12:32 PM | #15 |
Mudslides 'r my specialty
http://www.macsspring.com/website/we...pkitsframe.htm
$82.14 for a flip kit. Free shipping for orders over $100.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
05-02-2005, 02:06 PM | #16 | |
Slonaker |
05-02-2005, 06:54 PM | #17 | |
I agree 100% that It would be a better alternative than the air shocks and I do plan to do a c-notch and go lower. But, you know how it is when you just want to be done and it's late...I just figured that I will notch it and the brackets will come out all at once |
05-03-2005, 06:39 PM | #18 |
ironicly, you had exactly the tools you need to remove it.
05-03-2005, 06:47 PM | #19 |
\/ My Loves \/
Id just buy a kit man. I got mine from Sport Truck Direct. Didnt take me long at all! Spend the money and get it done fast. No worries on if your fabs were wrong...or if yu got the right angle...and if u fab wrong you wont have to fab again. Its just more easy imo. Go for the kit....theres my 2 cents.
78' Silverado - Blue - (In a Coma) 04' Silverado -Red- 383 Stroker in progress for the 78'!!! |
05-03-2005, 06:48 PM | #20 | |
05-03-2005, 10:30 PM | #21 |
senior member
what i dont understand is they say heating is not good for ur springs? why is it ok to powder coat your leafsprings then?
69 GMC bagged |
05-04-2005, 12:20 AM | #22 | |
05-04-2005, 12:20 AM | #23 | |
Happy to be here
05-04-2005, 12:22 AM | #24 |
Happy to be here
Dang Jeremy, brilliant minds do think alike. Look at our post times....
05-04-2005, 12:37 AM | #25 |
haha... i guess you're right Ken, great minds to think alike.
