Got Light Emitting Diode?
how to lose 50lbs in 2 days
and its 2 days cause i am too lazy to bust mu butt to get it done in one. the cast heads weigh 55lbs and the aluminum ones weigh 25. i will finish it all up tomorrow. as it sits all the valves are adjusted. so on with the intake and headers and we are done and then
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler Last edited by 68w/sbc406; 05-01-2005 at 05:00 AM. |
Its Magically Delicious
thats a mean diet ... what are the specs on the heads
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
they are ZZ4 heads 58cc, 194 intake http://67-72chevytrucks.com/vboard/s....php3?t=140933
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
did you decide to change cam also?
Looks cool.
That's some funny math you are doing ![]()
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#6 | ||
was remembering this from last week or so and i knew you were possibly considering a cam swap.bumping up that compression may in turn make your cam sound a little more nasty
yeah i had a chance at a cheap roller cam but it wasnt any bigger than what i have and i would also have had to bought lifters and the keepers. i used a compresion claculator that some one linked to me and it was 9.3 and is now 10.4. i am also going to put a 1" carb spacer on so the heat wont transfer to the carb (its also supposed to help with torque) the next thing that i will have to replace will probably have to be the rear end
Thoes heads look sweet.
How do you like the manual brakes. I just picked up my new master Cyl. Kinda hope I don't regret going manual. I have to shoot it with torch red this week.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
manual 4 wheel drum.......my legs are buff. i have all the disc stuff waiting to go on.
well today wasnt very productive. i had to hit up 2 part stores to find the part i needed to put my temp probe in the head. but i got my headers bolted on, temp probe in, plugs in intake on, dizzy in, carb spacer on, linkage and kick down cable on. now i moved on to the PS pump, it leaks and i bought a alan grove bracket for it so it wont use any head bolts, but i need to drill and tap two holes on the bolck and put the gasket kit on the pump. then hopefully it can go back together.
Nice heads!!
#13 |
thank ya
#14 |
Psalm 23
Very nice.
Good lookin engine compartment.
71 GMC Fleetside C15(cab), 3/4 ton, 350, Holley Street Avenger 570cfm carb, TH350 trans, Leaf-springs, 2WD. "Peter are you sleeping on the job? No I have a bug in my eye and I'm trying to suffocate him." - Family Guy |
#15 |
Whooo Hoooo! Looking nice. Can't wait to see it at our next get together.
Enjoying life again. Time to get those big blocks rolling. |
#16 |
just more gizmos and gadgets. thanks guy
#17 |
well this PS pump is kicking my @$$ i bought aftermarket brackets for it and a seal kit since it leaks like a pig. well it was fun puting the seal kit in (not that hard) but then i put it back together and realized i needed to drill a hole in the case to get access to another threaded hole on the pump inside, well with the new "O" ring the pump did not want to come back apart. once i got it all back apart got the hole drilled and put today i started messing around with the brackets and tapping the block so it could be bolted on.then realized that my valve covers BOTH have a big hole (like where a cap would go but they arent threaded) and a PCV port. so now i have to figure out what to run in all the holes. one will be a PCV and the two big holes will be both breathers probably, but what about the other PCV size hole??? also had to go the the auto store twice to get the right size belt for the PS. and tomorrow i get to go to the dealership to find the gromets and stupid stuff. at this point i am frustrated with all the little issues and you can tell by the way the shop looks.
#18 |
and more
#19 |
YEAH man!! I like those heads as well; very cool. I think maybe I'll take a closer look sometime.....like maybe at your house.......like maybe about 2 in the morning....like maybe with a REALLY quiet air gun!!!!!!!
1972 Chevrolet Suburban ('68 front clip), 2wd, 350/350, factory tilt 2008 Kawasaki Concours 14 ![]() 1997 Harley-Davidson Soft Tail Custom 1948 Chevrolet Coupe (project) 1972 Porsche 914 Last edited by 68plus4sub; 05-04-2005 at 01:39 AM. |
#20 |
we wont have the same valve covers anymore, these are center bolt
#21 |
Nice work! Can't wait to check out the difference!
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
#22 |
nice of you to join us, where ya been?
#23 |
71 Cheyenne SWB Fleetside
hey 68w/sbc406, you should post some more pictures of the complete engine with the intake on it. so we can see how nice it looks.
joel
#24 |
Have considered Copper collector gaskets ? I have them in my 84 and they are great. No blow out's.
#25 |
Have you considered Copper collector gaskets ? I have them in my 84 and they are great. No blow out's.
