Old 05-01-2005, 11:49 AM   #1
laid67c10
laid67c10's Avatar
need some opinions on cabs
well i have found a big window cab that i have been thinking i wanted but now i am thinking i like my small window cab and i can't decide what to do so anybody else got any suggestions the big window cab is rust free and has all glass and doors and automatic steering column and auto pedals, my small window cab needs a rocker repair on passenger side has some light rust in a couple of other spots and has clutch pedal and standard column when it's all put back together it will be stuffing a small blcok with a auto tranny, what should i do?
49 Chevy - currently under construction being bagged and hunting for a LS drivetrain!!!
09 - Harley nighttrain on air ride!
laid67c10 is offline   Reply With Quote
Old 05-01-2005, 12:02 PM   #2
guyryan100
guyryan100's Avatar
I think the big window cabs are generally more desirable, and sounds like it may be less work. But if you perfer the lil window, it's your truck so get what you want. If it were me I'd trade out the cabs.
guyryan100 is offline   Reply With Quote
Old 05-01-2005, 12:06 PM   #3
purple gas
well, changing from a standard to auto column and pulling the clutch pedal isn't a very big job. But you have to aquire the column, that costs a few bucks. If you have rust repair, you have to aquire parts to fix it, that costs a few bucks, you have to fix the rust, or have someone do it for you, few more bucks. Assuming both cabs being of initial equal value, you'll have more money into the small window cab just to get it usable. You have to decide how much you want to invest in your truck, and balance that against which style of cab you prefer. I like the looks of the small window, but I prefer driving a big window, much better visability, therefore safer and less likely to get bent. IMHO Good luck on YOUR descision.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 05-01-2005, 12:52 PM   #4
GloryHound
Working on a Nova.
GloryHound's Avatar
If you lived closer I would trade you my two best cabs for that small window. I like the look of the small window.
GloryHound is offline   Reply With Quote
Old 05-01-2005, 08:43 PM   #5
laid67c10
laid67c10's Avatar
yeah for some reason it's starting to grow on me, i like the big window but am just really starting to like the small window, maybe it's cause most everyone leans more towards the big window, heck i don't know what i am gonna do yet....
Old 05-01-2005, 09:46 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Personally, I like the small window, it seperates the 67 from anything later. Instant ID. I also like the way it looks.
however, Like said above, the big window IS a little easier to drive, and a 67 with the panoramic window is generally worth more.
Old 05-01-2005, 09:55 PM   #7
Sweet72
Sweet72's Avatar
Definitely go with the cab with the panoramic window and sell/trade the small window to me! Man I would give my left arm for a '67 sm. window short fleet... I think they look so cool.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 05-01-2005, 09:56 PM   #8
pjmoreland
pjmoreland's Avatar
Personally I think the little window looks best with a stepside bed, and the big window looks best with a fleetside bed.
pjmoreland is offline   Reply With Quote
Old 05-01-2005, 10:01 PM   #9
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
if it were a show truck and wouldnt see much road id go small. but for a daily driver id go big
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 05-01-2005, 11:33 PM   #10
boogie67
boogie67's Avatar
My 67 is a small window.I like the way it looks I did'nt at first but as I work on it more I think it looks cool.
77 swb starting all over again.
boogie67 is offline   Reply With Quote
Old 05-01-2005, 11:46 PM   #11
davidh
davidh's Avatar
67
I saw an article on custom classic trucks where the man who designed the 67 cab made the small window that way to give it a "coupe look" of the older cars. After reading that and looking at it I agree.I could really see it. I like either or but have always had a soft spot for the small backwindow. yes it's not as easy to see out of but mine has those "west coast mirrors" for it. They also changed to a blocky front end in 69 because the 67-68 nose was to refined for a truck. Personally, 67-68's are my favorites. If I had the small back window cab I'd keep it.
davidh is offline   Reply With Quote
Old 05-02-2005, 12:44 AM   #12
GloryHound
Working on a Nova.
GloryHound's Avatar
When your haulin' a big boat or tall load you can't use the rear window anyway!
Old 05-02-2005, 07:20 AM   #13
byrd
Union Electrician
byrd's Avatar
I've got a 67 swb small window complete rust bucket truck. Waht's it worth? and is anybody in here interested? have pics that I can email you to see it. Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 05-02-2005, 09:17 AM   #14
GloryHound
Working on a Nova.
GloryHound's Avatar
Is the rear window area at least salvageable to be welded into another cab by someone with s little skill?
Old 05-02-2005, 10:30 AM   #15
laid67c10
laid67c10's Avatar
thanks for the opinions guys i think i will keep it, i am just really liking it more and more each day and it will not be a daily driver just a weekend cruiser when i am done....
Old 05-03-2005, 12:59 AM   #16
RicksTrucks
RicksTrucks's Avatar
Is the big window cab for sale?
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 05-03-2005, 10:31 AM   #17
laid67c10
laid67c10's Avatar
maybe i might just keep it to the side....as my truck will be apart for a while and when it goes back together i may stick em both on to see which one i like better, i'll post it up in the sale section if i decide to sell it though....but it'll be awhile...but you never know i may run across another project...
