Old 05-01-2005, 11:59 AM   #1
guyryan100
guyryan100's Avatar
bench bleeding the MC on a dry system?
Ok, I've bled the master cyl and am about the bleed the lines -or i should say fill and bleed the lines as they're currently dry. Seems to me like as I'm bleeding some of the air will work its way back up into the master cylinder - how will I get that air out and did I waste my time bleeding the mc?
guyryan100 is offline   Reply With Quote
Old 05-01-2005, 12:14 PM   #2
Squid4life
Squid4life's Avatar
I Always bleed the MC, but never worry about the lines. Once it is all hooked up and you crack the lines at the wheel cylinders or calipers the gravity pushes the air outward, toward the bleeder. Sometimes gravity bleeding works better than the two person method of pump & release. Hope that helps!
Squid
'69 C10 LWB- 305, Holley 2 barrel, 700R4, 4/5 drop, dark blue primer!, cheap driver project...
Back on the road... In time to sell on Ebay.
Squid4life is offline   Reply With Quote
Old 05-01-2005, 01:06 PM   #3
tmcgrawlookalike
what squid said.i like to gravity feed the system.
tmcgrawlookalike is offline   Reply With Quote
