Old 05-01-2005, 01:36 PM   #1
71Shortbed
71Shortbed's Avatar
Quadrajet and manifold question
I've got a '71 with a 307 and standard 2bbl carb. Will a '71 4bbl manifold and quadrajet fit this? Will I need to swap throttle linkage, gas lines or what all is involved? I don't want to mess with it if it's a lot of hassle.
71Shortbed is offline   Reply With Quote
Old 05-01-2005, 09:18 PM   #2
dwaite72lnghrn
If the manifold is off a SBC then it will fit. The only thing is that a Q-jet is more carb then that engine can handle. Unless you have a really big cam and ported heads and big headers. '71 and up I think all used cable for gas pedal so as long as the carb has the bracket on the back for the cable linkage you can use it.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 05-01-2005, 09:47 PM   #3
Green Machine
Green Machine's Avatar
I would have to respectfully disagree that the q-jet is to big for a 307. Small prmaries and a vacuum operated secondary will feed it only what if can take. Maybe some rejetting and adjustment required, but anything would beat a worn out mini 2 bbl IMHO.
Fuel line on Q-jet is 3/8 and your 307 will have 5/16 from the pump, will have to alter fuel line anyway as 2bb is in differnt location. Might be best to swap fuel pump to 350 style and run all new 3/8 steel line from pump.
BTW I have run a q-jet on a 283 in the past and currently have a holley 650 spreadbore on a cast q-jet intake on my cuurent 307, only mod is a small (262) cam.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 05-01-2005, 10:14 PM   #4
71Shortbed
71Shortbed's Avatar
Thanks guys. After some research I think I'm going to go with an aluminum intake and a 600cfm carb. By the time I pay shipping on a used iron manifold I can buy a nice used aluminum Edelbrock. Sounds like I should be ok with the linkage and I'll redo the fuel line.
Old 05-02-2005, 06:56 AM   #5
GMC AMI
GMC AMI's Avatar
Little old 307
Here is my 307 after the swap. You will like yours better for sure.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 05-02-2005, 07:12 AM   #6
71Shortbed
71Shortbed's Avatar
Wow. That looks much better Mike. What carb are you running?
Old 05-02-2005, 07:22 AM   #7
70c10
67-72 Addict!
70c10's Avatar
Sharp looking motor Mike!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
