Reverse leaf springs
Can someone explain to me the process of moving leaf springs from top of axle to the bottom with pros and cons?
Do I loose any suspension capacity? Possible on 3/4 ton?
Bob |
Flip kit
I had a brain fart. Correct term is flip kit. Any help?
Bob |
Check the 73 guys. No load change. You will most likley need a C notch.
specialgmc70. I think was his name. Flat black long box. 17's. Tunnel Ram He did a flip on on his truck.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Anyone done the rear leaf spring flip?
I know there are a lot of GMC guys out there (and a few chevys). Anyone going to share experiences on flipping rear leafs to other side of axle?
Bob |
