Old 05-01-2005, 04:48 PM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
will 67-72 rearend fit 82 and 87 trucks?
my buddy has a 82 chevy with a 2.73 rearend in it and want to know if a 67-72 leaf rear will fit....also he has a 87 4x4 and want to know the same...if the 67-72 rears will fit the newer truck...i know you need to change the universals...
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 05-01-2005, 06:35 PM   #2
Blazer1970
Blazer1970's Avatar
Spring pad spacing on the older axle will be too narrow, so the pads would have to move. I also believe the pre-'73 axles are a couple of inches narrower. E-brake hookup will be different on the '87 also.
Blazer1970 is offline   Reply With Quote
