05-01-2005, 08:22 PM | #1 |
Fuel Pump Swap
Since I had the correct metal line for the truck I decided to go ahead and swap out the fuel pump. Pretty straight forward. Hardest part was getting that rod to stay put but after about 8 big globs of grease I got it to stay in one place long enough to get the pump in. Truck runs a little smoother now than it did.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
05-01-2005, 09:47 PM | #2 |
its all about the +6 inches
skokie, I did a write up in the FAQ on this...the small block has a hole in the front of the block that is tapped for a 3/8 bolt. You pull the short bolt out, install a longer one, and it holds the rod up for you. No cussing, no grease.
05-01-2005, 10:02 PM | #3 | |
Its funny that you mention that longhornman. After I was done I remembered that you did a write up on it So lessone learned for me. Next time check the faq board
